Page 6 of 14 FirstFirst 1234567891011121314 LastLast
Results 51 to 60 of 132
Thread: Fiat Stilo by _Dejan_
  1. #51
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Today Im connect battery with my sistem...
    P.S. @koberko: I will answer you later...
  2. #52
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by koberko View Post
    hy
    My name is also Dejan, and I'm from Croatia (i will write on English so other users can read )
    And I also have Fiat stilo, but mine is red... hehe
    I'm thinking to install CarPc and i have couple of questions:
    1. I'm planing to install pc inside casing of mine stock radio/casete player unit (same as you). I was planing to put inside Aopen's mini PC, becouse it's a exact dimensions to fit inside (I will probebly remove original case and put inside just components). A cool thing is that it has it's own DVD ROM.
    But, problem with this is that I can't find that mini PC anywhere except e-bay.
    Where have you get yours components and at what price? Price for Aopen's mini PC is around 200€.
    2. I don't want to have additional amplifier in car, so I will try to use one that is inside stock radio/casete player unit. Do you think that this will be a good option?
    3. I alsso don't want to have additional radio, so I want to install TV/FM turner on PC... Is there some mini PCI TV/Radio cards, or I will have to put external that connects via USB?
    4. What LCD have you use? And what is price of that?
    5. What have you use to build mask (housing) for LCD? I have a friend that works at El. teh. school and they have there CNC machine, and he have told me that they can make ma that mask from aluminum. I's also planing to make entire center panel from aluminum.
    6. Where do you live in Slovenia? I'm often in Slovenia (I have some friends in Celje and Ljubljana), so if is ok with you we can meet somewhere.
    tnx.
    1.)If you can't find that mini PC anywhere except e-bay then buy it from ebay. Im buy few components from cartft online store, and few diferent shops... My components has been expensive about 1000-1500€
    2. I don't know how you will use amplifier from stock radio... But If I remember right, is possible buy amplifier which you connect to usb and output power is same as original radio...
    3. I dont know if is somewhere mini pci card, you can buy normal pci or usb card. If you have enought space you can put it inside case and connect it direct to motherboard...
    4. I use CTF800 LCD price is about 250-300€
    5. Mask we are build from 2din mask(Blaupunkt) for normal headunit. Then we are put external case for LCD(which is in packet) into this 2din mask, glued it. And use kit for repair lines...
    6. I live near Ljubljana...
  3. #53
    Apr 2008
    power cable
    Hello,
    I also have a Fiat Stilo SW MJ and I am completing my project, I need to know where to pass the power cord from the passenger battery, perhaps you could show me pictures.
    Thanks.
  4. #54
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by Feynman View Post
    Hello,
    Thanks.
    Sorry I don't have pictures of this, but I will try explain you...
    If you remove panel which is between windshield and front door you will see one black "cork" then do hole and just put cable cross hole...
  5. #55
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Something new for my carpc:
  6. #56
    MarcelP's Avatar
    Nov 2007
    Germany
    Quote Originally Posted by _Dejan_ View Post
    Can you make a speed comparison between HD and SSD? The times for starting Windows!
    My Project: German/English
  7. #57
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Sorry I can't do windows boot time test...
    I can give you only this tests:
    SSD vs hitachi 160GB SATA:
    SSD vs WD Raptor 36GB 10000rpm SATA:
    SSD vs WD Raptor 74GB 10000rpm SATA:
    SSD vs 2x Hitachi 320GB SATA RAID 0
  8. #58
    Apr 2008
    Man that SSD musta been expensive, probably more expensive then the whole system you put in there so far =)
    i watched all the videos and saw all the pics i love what you did a true modder...
    good work man
  9. #59
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by lucegunz View Post
    good work man
    No SSD has been on of cheapest thing in my carpc system. Im get it for 122€(EURO)...
  10. #60
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Im buy something new:
    What is in box?
    Performace:
    Read:
    Write:
    And Im buy another Fiat Stilo but smaller
  1. My Fiat Stilo 99% complete (Lilliput in Dash)
    By antofa007 in forum Show off your project
    Last Post: 06-03-2010, 01:42 PM
  2. Fiat Brava OBD-II Compatible?
    By Pharazon in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-22-2006, 11:12 AM
  3. My First Carputer..fitted in a Fiat Bravo (UK)
    By Daz155HGT in forum Show off your project
    Last Post: 10-22-2006, 07:57 AM
  4. Microsoft, Fiat Announce In-Car Computers Partnership
    By uxu in forum General Hardware Discussion
    Last Post: 07-19-2004, 07:45 PM
