What skin are you using
Well, my setup is finally coming together and looking more and more like it's complete.
Here's my current setup (also in my sig, heh):
- VoomPC I Mini-ITX case
- Commell LV-677 DC-DC Motherboard
- M2-ATX 160w PSU
- Intel Core 2 Duo T5500 1.66GHz 667MHz FSB 2MB L2
- 1GB (2x 512MB) DDR2 667 RAM (i believe it's Kingston)
- Dynamix 8" Touch screen
- AuxMod
- Audio line loopback filter (filter out noise on audio line)
- Holux GR-213 GPS receiver
- Targus 4 port USB hub
- My cell phone as internet (Sanyo PM-8200 w/ Sprint PCS Service)
Future Plans:
- OBD II interface\setup
- Permanent Wifi connection.
here are some pictures i took, it's a mixture of different times when i took it, the water look is the most recent ones.
Click here to go to my Villagephotos.com photo gallery. (There's 3 pages of photos on there.)
I do have a 1 question though, does anyone know how, if at all, to get an actual 10, 20, 30, 40 etc MPH picture behind the speed on my GPS stats page? it's just a blank white box.
let me know what you think, comments\suggestion\questions of your own (even if you don't know the answer to my question.)
thanks
2006 Mazda 3 S Series
2.3L 4cyl Engine
Current Build
- Commell LV-677 Motherboard
- Intel Core 2 Duo T5500 CPU
- Dual 512MB PC5300\667MHz RAM
- Seagate 80GB SATA HDD
- M2-ATX 160W PSU
- Dynamix 8" LCD Touchscreen
- VoomPC I Mini-ITX Case (Black)
i'm using the roadrunner FE and DigitalFX skin
2.3L 4cyl Engine
Current Build
- M2-ATX 160W PSU
The link to your photos doesn't work for me
Carputer Progress:
Re-do fabrication of screen [DONE]
Add mini-USB and micro-USB power from M2-ATX [DONE]
Teardown PC [100%]
Add HDMI > VGA converter [0%]
really?
what happens when you click it? it's just a simple link to the public folder of all the pictures i put up...
2.3L 4cyl Engine
Current Build
- M2-ATX 160W PSU
Can't access error - might be the network here, maybe I'll try it elsewhere
Carputer Progress:
Teardown PC [100%]
does your network have some type of filtering or accessability restrictions or is it full unrestricted\filtered access to the internet?
2.3L 4cyl Engine
Current Build
- M2-ATX 160W PSU
nice install. whats the model number of that dynamix screen that you are using? how is it?? i want to get the Dynamix 816 monitor, but i havent heard much about it
[::::::::::] 100% - Planning
[::::::::::] 80% - Computer
[::::::::::] 0% - Fabbing
CarPC:
SP13000 / 120GB SATA 2.5" / 512MB DDR
8" Innovatek TS / Globalsat BU-353 / Engenius EUB-362 EXT
Slot load DVDRW / PS3 Wireless Keyboard
that's exactly the one i have.
it's kind of a pain though, it's only mounted with industrial strength 3M double sided tabe used in car installation stuff. i nor anyone in the bestbuy mobile install bay at the store i used to work at could help me mount it permanently because the backplate of the screen is like a very thin aluminum and has holes literally the size of o that.
2.3L 4cyl Engine
Current Build
- M2-ATX 160W PSU
Hi,
I like your install. I'm doing something similar myself using the Japanparts box and the VoomPC-2. The M2-ATX supports an ignition sense connection. Where did you get this? Did you splice cables from the HU?
Thanks,
AQ
