Page 14 of 22 FirstFirst ... 45678910111213141516171819202122 LastLast
Results 131 to 140 of 220
Thread: Chrysler 300 Touring CarPC build/install with pictures
  1. #131
    Constant Bitrate Nermin's Avatar
    Dec 2007
    Snellville, GA
    today I finished with building my PC - the error I had was fixed with simple rerouting in BIOS from SATA to IDE HD and installation worked just fine
    I installed all necessary software and as you may see it works flawlessly
    I must compliment touchscreen quality - especially touch response speed and sensitivity
    [-------------] Hardware Status
    [-------------] Software Status
    [-------------] Fabrication Status
  2. #132
    Dec 2007
    Snellville, GA
    now I can't hardly wait to start fabricating other components to their space in the car. today I painted and attached component panel fan and hinges that will swing enterior of the relays, fuses and distribution blocks
    tomorrow I'm hoping to drill some holes in my trunk and at least atach the panel and figure out locking mechanism
  3. #133
    Dec 2007
    Snellville, GA
    also, I got my hands on one of these
    3D Galaxy II from Gigabyte liquid cooling system - I will install this and run the fans/tubes all over my entire system and the interior of the car to keep everything properly cooled down
  4. #134
    Dec 2007
    Snellville, GA
    as always, pictures will follow ...
  5. #135
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by Nermin View Post
    congrats, your way ahead of me..... My install went down hill yesterday, it will all be explained in my worklog. Its almost like some strange force does not want me to succeed.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  6. #136
    Dec 2007
    Snellville, GA
    I totaly understand Jack - when I saw the error screen after my initial set up I was ****ed, now everything is just fine
    today, in Atlanta, rain was just pouring so I couldnt do as much as I had intended to - however, I did measure/cut some holes on my panel and I did drill into my trunk, that was just about everything
    tomorrow another working week starts - at least for me - so untill next weekend I will hold on larger steps
  7. #137
    Jul 2007
    Miami
    Let me ask, are you staying with IDE, or did you get the sata to work? My case, although larger, cannot fit everything comfortably. The placement of the IDE port on the KINO is not in a good place. It is hard to get the IDE to flex and it takes up alot of space. Sata the cables are thin and I can easily bend them. I ordered IDE to sata adapters.... One goes to the back of the HDD and sits upward, which allows it to fit. For the DVD ROM I had to really do some searching and found one that lays flat, but im scared it may block the processing fan. I might have to cahnge it to a blower style fan, were it blows out air from the side and not the top.
    http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN:IT&ih=012
    http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN:IT&ih=022
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  8. #138
    Dec 2007
    Snellville, GA
    I'm definitely staying with IDE - I hate having adapters on the mobo
  9. #139
    Jul 2007
    Miami
    The adapters dont go on the MoBo, but on the drives themselves, except for the long one, it is Bi-Directional, so you can use it on the board or the drive. I want to use IDE, but my case doesnt have romm at all............... Since I ordered the adapters and a whole bunch of other things (antenna adapter for HD radio) I decided to just order the correct fan for the MoBo. I figure if I have to wait a bit, I might as well order what I need.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  10. #140
    Dec 2007
    Snellville, GA
    I still have IDE to SATA adapter that, beleive it or not goes on the mobo - ah well ... good luck with that space
  1. chrysler 300 2005
    By anaviel in forum Worklogs
    Last Post: 01-20-2007, 08:02 AM
  2. Scion XB or Chrysler 300 Base Model?
    By hookid in forum Off Topic
    Last Post: 04-09-2006, 09:46 PM
  3. Chrysler 300 -- need aftermarket headunit?
    By mikemccoy in forum Car Audio
    Last Post: 12-15-2005, 09:05 PM
  4. @005 Chrysler 300
    By MGD in forum Show off your project
    Last Post: 12-10-2005, 09:20 AM
  5. My Chrysler 300 Install
    By rb_selectblend in forum Fabrication
    Last Post: 08-11-2005, 06:43 PM
