Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 47
Thread: Speedy (Mazdaspeed6 Carputer Project)
  1. #21
    Constant Bitrate golfguy's Avatar
    Nov 2006
    Fort Worth, TX
    Audio System
    Before I started my carputer project, I put a new audio setup in my car. The Mazdaspeed6 comes with a Bose audio system that sounds nice enough, but was not nearly loud enough, especially when I had the sunroof open and all the windows down on the highway. Several posters on the Mazda6Club forums have noted that the head unit on the Bose systems outputs pretty good quality, reasonably flat response signals at line level. So I decided to put new amps and speakers in the car.
    Inspired by this thread: Chris' Mazdaspeed6 Stereo Install I built an amplifier rack for the back of the trunk, and put RAAMMat noise dampener and Ensolite foam in the doors (a gigantic pain and lots of work, but very worth it). Then I removed the Bose amp and spliced the head unit outputs to the inputs of the amps. I prefer a stock look for the interior, so I did not change the speaker grills, but I did run new, heavier gauge speaker wire for the speakers (another huge pain, and not so much worth it). I used Infinity component speakers in the front and Blaupunkt coaxial speakers in the rear.
    The pictures show the amp rack installed and my 12" Rockford Fosgate Sub. Behind the amp rack and between it and the back seats I mounted the stiffening capacitor and the wire distribution terminals, so that I could remove the amp rack without having to work the wires back through the holes under the amps so the wiring wouldn't look like a rat's nest.
    There's still plenty of room for my golf clubs behind the sub, even though it doesn't look like it!
    Any day is a good day for golf.
    Mazdaspeed6 Carputer Progress: Gone
    (Check Speedy's Install)
    Speedy was traded for a 2004 350z - Install complete except for permanent screen installation.
  2. #22
    Jun 2003
    Memphis - TN
    Did you know you can buy a factory piece from japan that will house your LCD as well as fold down?
    I have it in my Speed6.
    Pics are here..
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  3. #23
    Nov 2006
    Fort Worth, TX
    Yeah, I've seen it. If I remember right it was quite expensive. I'm a little concerned about long term reliability with all the gears and moving parts as well. How long have you had yours?
  4. #24
    Jun 2003
    Memphis - TN
    Over a year. This is an OEM part btw. quality is top notch. Well worth the money. I will buy another for my wife's 6.
  5. #25
    Aug 2007
    Like that you have used a Powermate in your install, I have one in mine and I find it absolutely essential. Great job mate!
  6. #26
    Nov 2006
    Fort Worth, TX
    Quote Originally Posted by angel120 View Post
    Whoa, a fellow 6-er! Are you on the Mazda6Club forum? If not, JOIN!
    Nice install, I wish I caught this thread earlier cuz then I would've been able to toss my two cents.
    Looking at your radio - what Aux input solution did you settle on? I'm using AuxMod that runs in through the tape deck connector, so my display always says "Tape Playing". Yours says EX888, so are you going in through the Sat Radio port? Which adapter is it?
  7. #27
    Low Bitrate angel120's Avatar
    Apr 2008
    Queens, NY
    Quote Originally Posted by golfguy View Post
    The Car2PC adapter via the CD changer port. The car2pc's USB function was giving me some annoying problems, so I decided to just use it as an aux-in.
    2003 Mazda 6i Sedan - White
    CarPC in the making!
  8. #28
    Maximum Bitrate LinuxRacr's Avatar
    Jul 2003
    Dallas, Texas
    Very nice install there GolfGuy! You ever hang out over on http://www.dfwmazdas.com or http://www.mazdas247.com? Also, you should try to come to some of the local meets we have here.
    My Car: 2001 Mazda MP3
    My OLD Carputer project: Here
    Completion Progress Bar: [**********100%]
    Current build! Here
    Completion Progress Bar: [*********99%]
  9. #29
    Nov 2006
    Fort Worth, TX
    Thanks much. I've looked in on mazdas247, but never bumped into dfwmazdas. I'll check it out. When do y'all meet?
  10. #30
    Jul 2003
    Dallas, Texas
    Usually on Thursdays regularly. There is a thread on the site referring the the Thursday Night Meets.
    Current build! Here
  1. Carputer Project
    By Final in forum General Hardware Discussion
    Last Post: 01-20-2007, 07:32 PM
  2. Carputer TIME!! please HELP!!
    By CoupeE46 in forum Newbie
    Last Post: 11-26-2006, 06:52 PM
  3. My Carputer Project, need advice
    By natesimpson74 in forum General Hardware Discussion
    Last Post: 09-21-2005, 01:14 AM
  4. Project Car needed some gearheads on Carputer
    By FastAttack in forum Newbie
    Last Post: 11-04-2004, 01:33 AM
  5. starting my first carputer project, have some questions
    By ssa_whiskey in forum General Hardware Discussion
    Last Post: 02-24-2004, 03:43 PM
