I am very familiar with the A3 chasis (I have owned 3 of em! '96 Jetta Trek, '95 Jetta GLX Vr6 and a '99 Cabrio) and I think the cubby hole would be an ideal location. You could remove the whole console and install the monitor from the back after cutting out the cubby hole. All you would really have to do is pull the console and cut the cubby hole out, place blank piece of plastic over the opening and epoxy it into place. Then get your monitor (one with a clamshell headrest mount may be the easiest and cleanest way to go) and cut the opening out for it....install and voala.....of course its easier said than done, but this method would be easier/less expensive than fabricating a custom console for it.Originally posted by Stavros
I found some better pics that show off my center console better. These aren't from my car, but have identical units. I'm thinking of taking out the cupholders and putting a 4-5" display int here and make some custom molding. Tell me what you think now Superfly!
I have seen that done before in a show car. Looked good but cant imagine it was easy. Judging by what he is saying, he does want to invest tons of time constructing the system.I'm pretty sure the Vent, cold & hot air, A/C controls are all controlled by vacume lines. You could relocate those controls down where the cupholders are and move the defrost button, Pwr Window buttons etc.. to where the ashtray is. Obviously you won't have an ashtray anymore but you will have space for a 7"wide screen Redant TFT display. I'm pretty sure i thought i've seen this mod done before but i can't remember if it was in a magazine or on the net.
Another way you may want to think about going (although its MUCH more expensive) would be to get an all in one unit...ie an alpine/sony/eclipse flip out that has cd/radio/tv......and aux inputs. That means all you would have to do would be to install the deck an then run the wires for you video/audio...dunno but worth a shot!
LinkBack URL
About LinkBacks
) and its been upholstered since this picture, but its in the same general place:
In the meantime decided to go with a 300W inverter to get the job done (yes, it, my powersupply and motherboard are all grounded!)
