Results 1 to 8 of 8
Thread: 2005 FX4 SuperCab - My first bezel!!!
    Aug 2007
    Wow, i have really had my fill of sand paper and primer.
    Used an epoxy bumper repair kit from Canadian tire (little white and black tubes, sands great, and $9.95), and rusto-lian primer + flat black from Home Depot (matches the interior ok, but a bit fragile so i added a lot of coats).
    I sanded with 200 grit (on a little orbital), then 400/600 (by hand), followed by a very fine steel wool scrub pad, get the smooth uniform feeling.
    I wanted to keep a radio as a backup as I move my mac mini between my two cars, so I gutted a a cheap double din kit for the parts to mount the radio, then used tape to mark off the lines and build the border, looks pretty flush.
    Thanks to grayvader for the stock picture of the bezel.
    His work and my inspiration is here;
    http://www.mp3car.com/vbulletin/show...de-empire.html
    Aug 2007
    Forgot to mention, took about 20-25 hours..
    Variable Bitrate bambam's Avatar
    Dec 2004
    Upstate New York
    Quote Originally Posted by stavrosg View Post
    Well it looks like your time spent was worth it because it looks really good! Looks great in the dash, very nice install.
    "Imagination is more important than knowledge." -AE
    Constant Bitrate Tensai's Avatar
    Jun 2006
    Texas
    Very nice! What front end are you running? Is it CF or RR with a skin?
    Is it that it's fun? Or that it lets you forget yourself?
    Aug 2007
    CF2.
    Got it up and running faster than RR. And you can configure anything in the car.
    But RR has nicer skins i find..
    Constant Bitrate Pathos's Avatar
    Jun 2004
    St. Louis Mo.
    Looks pretty good from here
    "A rose by any other name is still a flower"
    Variable Bitrate eric_barcus's Avatar
    Mar 2007
    id say it looks mighty good! i like how its "flush" form teh side view where the viewing angle is the same as the rest of the dash
    Aug 2007
    Thanks. I am very happy the way it turned out
  1. Replies: 10
    Last Post: 12-18-2006, 09:50 PM
  2. Fiberglassing Gauge Pod in Bezel *pics*
    By jmilin5931 in forum Fabrication
    Last Post: 10-04-2006, 09:04 AM
  3. 2002 Silverado Custom Dash Bezel
    By AZ_Silverado in forum Fabrication
    Last Post: 08-09-2006, 02:46 PM
  4. FS: 2003 - 2005 Accord Bezel for Lilliput
    By calvincbr in forum Classified Archive
    Last Post: 12-04-2005, 02:15 AM
  5. Where to DL old version of RR?
    By accentsound in forum Road Runner
    Last Post: 07-12-2005, 01:51 AM
