Page 3 of 8 FirstFirst 12345678 LastLast
Results 21 to 30 of 78
Thread: My first CarPC in my Subaru Legacy (Estate) - With LED sign!
  1. #21
    Dec 2007
    Awesome install.
  2. #22
    Jun 2006
    Ventura County
    Wow...super nice install...
  3. #23
    Dec 2007
    Iowa
    Thanks!!!!
    Gotta give you a little more credit!! Thanks for doing ur install it pushed me to work on this centrafuse plugin that gives com port support. EXCELLENT INSTALL!!!
  4. #24
    Dec 2007
    Iowa
    Hey AwWuff,
    Where did you get that microsoft sync sound? I've been trying to find it all day.
  5. #25
    Jun 2008
    how do you intergrate the rear backup camera using USB camera? i am very interested on doing it.
  6. #26
    Low Bitrate AvWuff's Avatar
    May 2008
    Quote Originally Posted by Bxsteez View Post
    Hey AwWuff,
    I assume you are referring to the duh-duh-da! that plays when I hit the green button. I swiped the audio files from voicecmd.exe, the voice program on my pocketPC. But I didn't want them to be identical so I doubled up the first "duh".
    I've attached the file to this post.
    The camera is a cheapo little NTSC video camera -- $25 at Tiger Direct. Then, I've got a $40 super-wide lens on it. Finally, to show the image, it's connected to a USB TV Tuner "MSI VOX BOX" that I bought years ago and don't really use anymore. To actually display the image, I use Flash -- it's super easy and more importantly, it makes mirroring the image really easy (since you want it to be mirrored, like your rear-view mirror is).
    Cheers,
    -av
    Attached Files Attached Files
    Read about my Car PC at www.avbrand.com/projects/carpc -- LED sign now functional!
  7. #27
    Dec 2007
    Iowa
    Thanks a lot. I got centrafuse to react the same way as you have ur setup except for one minor flaw... I haven't quite figured out how to make it chime again when the voice command ends. I should be able to figure it out soon. Thanks for all assistance
  8. #28
    Jun 2008
    does the camera turn on when you shift the gear to reverse or did you have to press a command?
  9. #29
    Maximum Bitrate MoFo's Avatar
    May 2004
    TX
    wow, that is an excellent setup.
    I've given up on a solid voice command but you have peaked my interest again!
    Could you elaborate a little more on your voice command? I would like to have a push button activation but I don't understand the relay part...
    Again, awesome system!
  10. #30
    May 2008
    Quote Originally Posted by ezland00 View Post
    When I switch into reverse gear, a small relay that is connected to my rear reverse lights activates, telling the computer (via the Arduino board) that I am in reverse. The camera appears automatically. It disappears when you're no longer in reverse, after you drive at a speed of more than 8 km/h (so if you are going back and forth, back and forth, the camera doesn't keep appearing and disappearing like some cars)
    Certainly. The pushbutton simply trips a small relay, also connected to the Arduino board. This tells the computer that I've hit the button. It pauses the music, plays the "duh-duh-dah!" sound, then mutes the system (in case some other app is making noise) and activates the voice command "listener".
    If you don't say anything within 4 seconds, or it doesn't recognize you within 10 seconds, it plays the "buh" noise, unmutes the audio, and resumes the music.
    If it recognized a command (depending on the command), it issues a verbal confirmation and then executes the command. If you hit the button again while it is speaking the confirmation, it instantly aborts. This is so that if it misheard you, you can cancel it and try again.
    I did all of this with the Microsoft Speech API SDK (free download from Microsoft) and VB6.
    Thanks for your interest!
    -av
  1. subaru legacy mounting problems
    By DarkFox1 in forum Fabrication
    Last Post: 04-02-2007, 01:18 PM
  2. Subaru Legacy GT Limited – Install Complete
    By xcntrk75 in forum Show off your project
    Last Post: 03-09-2006, 02:32 PM
  3. 1992 Subaru Legacy Turbo
    By Splinter in forum Show off your project
    Last Post: 01-21-2006, 04:15 PM
  4. LED sign random idea
    By hijinks21 in forum General Hardware Discussion
    Last Post: 10-18-2005, 11:32 AM
  5. Carputer | n00b | 91' Subaru Legacy RS
    By bones in forum Newbie
    Last Post: 07-10-2005, 11:09 PM
