As fusion said just make sure it is tied off and tucked up out of the way and you will be fine . I got a bit more room under my truck and in my frame rail but still I have 2 runs of 1/0 running along my frame from the engine bay and into the back of my cab. I wrapped both runs individually in split loom and wrapped them completely in 3m Super 33+ electrical tape and made sure they were zip tied along the frame and out of the way of anything.
You should be able to run your wires along with your brake lines or fuel lines and such. I wouldn't tie the wire to the lines but should be enough mounting points and room to tuck the wire up into the undercarriage of the car.
LinkBack URL
About LinkBacks
(I'll edit the post)
