Hey Fusion.
I need help with something.
I pretty much followed your setup example cause I really liked the way it looked, and I wanted the ability to have a Hardware solution for Volume. Since you helped me out before -- I need help again.
A little background.
I have the same EQ you have mounted under my TS, and am Amp/Sub - so lots of RCA cables/ etc.
My 4 channel amp gets the remote turn on from the M2-ATX - the Sub is powered and does not have a Remote turn on - It turns on through the RCA's. Its a Blaupunkt THb 200A compact powered sub - fits under my seat.
Link
http://www.crutchfield.com/p_023THB2...tab=review#tab
Anyway, I keep blowing my Radio Fuse - so nothing powers on since there is no ignition signal sent to the M2-ATX.
The only thing that is hooked up to the radio harness is the SPDT switch example you gave me ( center off - non LED) AND the Clarion EQ. How is yours hooked up? What powers your EQ?
(A side note, I think something was backwards with the SPDT switch, because I followed your example and hooked up 1 to the Acc and 3 to 12v constant - but the label 1 on the switch was "Always On" and 3 Turned on and off with the car - not sure why that was happening.)
Can you give me any ideas or insight for why I keep blowing the radio fuse? I've blown 5 fuses so far, (installed if Saturday).
Anyway, I am pretty beat after boarding all day, but I wanted to get the ball rolling -- I'm trying to diagnose this and resolve it soon. I'll post some more info tomorrow.
Anyway, thanks again for all the help + inspiration -- I hope you don't mind me semi copying your setup.
LinkBack URL
About LinkBacks
