2002 Frontier-PC project
So I decided to put a PC in my truck. 2002 Nissan Frontier Crew Cab
PC specs below.
Motherboard/CPU: D945GCLF2 w/ Intel Atom dual core
Memory: 2GB Patriot PC5300 Low Latency
HDD: 250GB Seagate Momentus Black 7200.3
PSU: M2-ATX
Case: Mocoso Black mini box (modded w/ 2 fans)
Internets: DataAlliance 400mW USB WiFi adapter w/ RealTek 8187 chipset, 9dB Omni Antenna
USB Slim CD Slot load
Input: Logitech DiNovo Mini KB
Display: 7" Double Din Motorized LCD from Revo-Sys, comes with 45w/chan Amplifier
Radio: Visteon HDZ300 w/ Mitch's cable
USB Hub: Targus USB 2.0 Ultra mini hub
GPS: Globalsat BU-353 USB
Thats all i can think of listing since they are all over the place.. lol
Assembly started today.
Here's a pic of the mobo assembled so far. All works so far connected to the M2-ATX.
LED and Reset is connected to my old case, lolz. I also made my own P4-P4 cable, apparently I have it too short so I just turned the M2ATX for now.
Bought the mobo, case w/ M2ATX, HDD, USB CD/DVD, and the Lilliput from eBay using the MS 30% cashback (last day before they went to 20%)
$224 cashback on the way in 2 months.
Update:
Returned the Lilliput Indash back since the screen will not retract all the way out because it hits the part of the dash. So it about 30degrees off even if its at the bottom of the pocket. It would have to stick out about 1.5" from the bezel and it does not look good. So I am switching to a Doubledin.
I ordered a DWW-6500 clone from revo-sys since it went down to $485. Later I got an email that the price is for the replacement.
The new replacement is a 7" Innolux LCD with Antiglare, 4wire touch screen overlay, Built in Mic, a 4x45watt amp, but no AM/FM radio tuner and no CD/DVD drive installed. It may have a slot for an addon (I hope) All these in a Double DIN unit.
side view pic below and the front screen.
This is basically the same screen unit of their X300 model, just without the PC.
Update: New Display is being shipped.
7" Double Din from Revo-Sys
Finally I'll be able to install these things.
It has an Internal CD/DVD slot, but the one they are shipping to me will not have it. I can ask for it when they have it.
Received the display yesterday, everything from the picture above came with it. The VGA cable is heavy duty and is quite long. The 2 blue USB cables were very long as well, so i wont be needing USB extensions.
so here's whats done so far to the PC.
here's the Display I received.
Back of the display. The 2 RCAs next to the USBs are 2 VIDEO Inputs, the other 4 are Audio In.
Motorized Screen flipped out, CD slot is empty for now, until I get the bracket.
Only thing not working right now is the touch screen.
it has Serial-USB built in, I do have the drivers for it, but the Touchkit software cannot find the touch controller.
The Power button on it does not work for the display, It actually is the power button for the PC, it has 2 wires on the back to connect to the motherboard. Also a Reset button next to the VOL-, 2 wires also built to the harness. The hole on the right side of VOL+ is the MIC, has 2 wires on the harness as well.
It doesn't seem to have an ignition wire, It has 2 +12v wires (Yellow).
I'll need a relay to power it on, or just put it in the ignition wire from the stock harness.
Hey how's the project going? I'm thinking of getting that same Revo-Sys screen myself. Have they been a good company to deal with for you? Responsive, easy to order? I tried calling them but nobody is answering the phone.
So if I can tell correctly from the photos and your description, the main harness has 4 pairs of speaker wires, 2 constant power wires, 1 ground wire, 2 wires for pc power toggle, 2 wires for pc reset, and 2 wires for the mic, correct?
Did you get the DVD drive yet and is the overall product quality good?
Thanks in advance for the info!
I'm waiting for the new screen to be shipped.
I couldn't get the touchscreen to work. I got the rev01 of the unit.
Just received an email yesterday that they are sending me a rev02 version.
They are including a DVD drive in it now, no charge.
Correct on the harness, but it has 1 more Ground wire. They can be tied together like the Power wires.
Well, quality isn't like a name brand one, lolz. Its chinese, as i've expected. Cant really tell as far as reliability, just trying to get it to work for now.
It's best if you email them, I couldn't get ahold of them on the phone either. But they respond to ya within a day.
Communication and support is great, no problems so far.
Update: (did last Sunday)
Fixed the engine whine noise by adding a GND Loop isolator.
Wrapped the Data and Audio wires in split cable tubing. Isolated from the power wires.
Prewired AV cable to the Display unit which will be connected to the connection (see below). Apparently now that his got connected, the Amplifier now sets the audio from the PC automatically. I used to have to switch the source each time it powers on.
To do Next: (hopefully this weekend)
I bought one of those 3 terminal AV wall plate, drill holes to the console pocket in front of the shifter. Put AV terminals there which will connect to the Display. I'll be able to easily connect any AV source to this, which is the MagicSing Karaoke
I'll have one video jack left which will be for Back-Up Cam, which ill purchase later.
Took a video of the screen today, around 3PM. with lots of sunlight on the rear right side.
This is starting up from Hibernation.
[media]http://vimeo.com/3036681[/media]
Just wondering how things are going with the new display. I have a Xenarc 700IDT that now has a bad touchscreen controller. It's just about 1 year old. I don't want to go this route again and am thinking about the Revo-sys monitor you have.
Right now I have a Clarion headunit to control the volume and take the audio from the car PC. The headunit then feeds the main amp. This is all setup in my '96 Camry.
The audio out from the PC can go to the revo-sys monitor, right? Then can it feed it to the main amp and control the volume as well?
Also, do you know where the manufacturer is located?
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
