Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 66
Thread: touchscreen steering wheel Carputer.
  1. #21
    Variable Bitrate Bimmerstyle's Avatar
    Sep 2006
    Belgium
    Quote Originally Posted by lesterine View Post
    slip ring? whats that? who said i was using a slip ring?
    How are you planning to get the monitor to work otherwise? You can't connect it with a cable because then you can't turn your steering wheel anymore.
    A slipring is the thing inside your steering wheel that connects the steering wheel electronics to a connector in the dash. It rolls on and off when you turn the steering wheel.
    BMW 525tds -Biostar I94GM-I4 -Celeron M44O 1,86GHz, M2-ATX, 1Gb, 320GB -HQCT RDS tuner -Creative Extigy -iBus controller -Lilliput 7" touchscreen -DLS Ultimate A7 amplifier -Focal 130K, 130V, 27V2 speakers
    Bezel Worklog-My Install -iDrive F01 RR Skin
  2. #22
    Newbie lesterine's Avatar
    Nov 2007
    green hill zone 1 with tails
    Quote Originally Posted by Bimmerstyle View Post
    i was confused by this term slipring. its actually called an srs cable reel. and yes thats what i used. i drive an rsx and the cable reel for that only has 8 wires and i need 11 (vga+touch+power line). so i actually got 1 from honda for a honda civic si. that has about 19~ wires on it. had to take it apart and do alot of work to solve to magnetic interference/ cross talk between the wires that was causing a very blurry image. lol after about 11 hours of anger i figured that part out with a very simple solution. but all is well
    chilidog tails chili dogs
  3. #23
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Aside from the safety issue, this is turning into a very interesting project. I'd love to have a keyboard (with IBM-style TrackPoint stick, if possible) set into the steering wheel, probably above -- but on a level with -- the airbag. I won't give up the airbag, but I've assumed previously that adding a keyboard meant, in a collision, that I'd get a faceful of keyboard delivered with the airbag. If I survived, those would be interesting scars to explain; I might even have to change my name to Letter-man.
    This gives me some hope I could get that keyboard in there safely so it wouldn't interfere with the airbag's operation. Hmmmm. A wireless keyboard there might be very interesting.
    Now I'm pondering whether I could mount a fixed keyboard independent of the wheel. On the Scion xB, that wouldn't obscure any controls or instruments. Hmmmm.
    You're inspiring me -- keep pluggin'.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  4. #24
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Next time you don't know what something is, either search or ask before summarily dismissing it.
  5. #25
    Variable Bitrate quantum's Avatar
    Sep 2005
    I'll jump in on the "I'd rather have an airbag than a chest full of electronics" bandwagon, but to each his own. Cool project otherwise though...
    Actually, I thought it was called a clock spring, not slip ring?
  6. #26
    Sep 2006
    Belgium
    The name slipring comes from older cars that had it. Back then it was a ball bearing or a brush that rolled over a metal ring. Hence the name slipring.
    In Dutch it's still called that and Enforcer used this name too so I assumed the name slipring was a common name in English.
    But whatever, I'm looking forward to pics of how you managed to do it. Nice project.
  7. #27
    Apr 2008
    i believe the term for them now in the uk is clock spring
  8. #28
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I think slipring is the name BMW use, hence the reason myself and bimmerstyle recognise it
  9. #29
    Nov 2007
  10. #30
    Nov 2007
    all DONE! works like a DREAM
    [media]http://www.youtube.com/watch?v=ye5uLmvdgwc[/media]
  1. 8-Core Intel Xeon 'V8" Sneak Peek - Dual Quads
    By stangg172006 in forum General Hardware Discussion
    Last Post: 04-25-2007, 05:41 PM
