Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 56
Thread: 2008 Yaris 4 Door Sedan PC Install
  1. #11
    Variable Bitrate rizaydog's Avatar
    Nov 2007
    North Central PA
    In this picture, I drew red lines to show where I needed to make adjustments:
  2. #12
    Nov 2007
    North Central PA
    Here is what I imagined it to look like after mods:
  3. #13
    Nov 2007
    North Central PA
    Scosche Mods
    First I used 5 minute epoxy to glue the trim ring onto the kit. After that set up, I cut out the bottom pocket to make a full double din opening in the front. Then I had to grind some plastic off so the Bybyte would fit between the top mounting brakets.
  4. #14
    Nov 2007
    North Central PA
    I also had to shave a little off the inside of the bottom brackets to make the bottom of the Bybyte fit between the two. In both instances, the Bybyte was a fraction of an inch too wide.
  5. #15
    Nov 2007
    North Central PA
    I removed some material from behind the front benzyl to allow the Bybyte unit to slide in right behind the benzyl. Before doing this, I had a gap between the benzyl and the front of the Bybyte kit. I could have filled the space between the two pieces. I decided this way should be better. I thought it would look better and be easier to reach the screen.
  6. #16
    Nov 2007
    North Central PA
    Then I used a hand file to clean it all up. I rummaged through my toolbox until I found the roughest file. I spent a lot of time with this tool smoothing everything out and trying to get all the lines straight. I used a small ruler as a gauge to check each side of the LCD opening to get is as close to straight as possible. Then I went over the entire project with 50, then 100 grit sand paper. I had some deeper scratches and gaps where I glued the trim ring in. I used some bondo and filled in the small gaps. Again, I went over these areas with 100 grit paper.
  7. #17
    Nov 2007
    North Central PA
    This is where I glued the trim ring:
  8. #18
    Nov 2007
    North Central PA
    This is a photo of it fully assembled, and before any mods where done:
  9. #19
    Nov 2007
    North Central PA
    I then installed the Bybyte unit into the install kit, and bolted it into the dash. I found out that I had to shift the Bybyte unit back on the frame by almost a 1/2”. The top and bottom of the Bybyte hit the inside of my dash. I then readjusted the bolts holding the Bybyte into the install kit so the Bybyte unit was pressed against the inside of my dash. Once the bolts where tight, I remove the entire assembly out of the dash. I then added filler strips to the inside of the install kit so they touched the Bybyte unit.
  10. #20
    Nov 2007
    North Central PA
  1. Replies: 13
    Last Post: 06-22-2009, 08:23 AM
  2. 06 Civic Mod PC Install - Pics
    By Morpheus1013 in forum Show off your project
    Last Post: 10-30-2007, 09:08 PM
