Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 56
Thread: 2008 Yaris 4 Door Sedan PC Install
  1. #31
    Variable Bitrate rizaydog's Avatar
    Nov 2007
    North Central PA
    Bootskin
    I installed Bootskin and additional skins. This changes the stock XP boot screen to whatever you want. I have about 20 different screens. I set Bootskin to randomize the screens so it is different every time I start my car.
  2. #32
    Nov 2007
    North Central PA
    Logon studio
    I installed Logon studio. This changes the screen that allows you to logon onto a user. I only have one user so I don’t have to logon in. This just flashes another picture while windows loads.
  3. #33
    Nov 2007
    North Central PA
    Gps
    GPS-
    I found a really good deal on Microsoft streets and trips with the GPS receiver on ebay. Couldn't pass it up. It works well, put I had some issues with it. By itself, it is not suitable for small touch screen in car applications. I found a thread,http://www.mp3car.com/vbulletin/road...2006-skin.html, that talks about adding a skin for S&T 2005 in RR. I used Softec's method which is the second from the top. It was very easy to add to the skin. Just extract two of the zip files into your RR skin, either the brushed metal(BM) or the brushed aluminum(BA). Then you have to change the name of the file "External_GPS.skin" found in your RR skin folder to "External_GPS.orig". Once that is done, you change the GPS_ST2006.skin found in your new downloaded zip file to External_GPS.skin. Then open RR config. Under GPS Mode = External. Under GPS Path, enter the path to your S&T exe file. Then reset your skin. Load RR, click on GPS. Done. The buttons are as follows: Key Definitions.
    Top row left to right – all music related
    Previous track, stop, play/pause, next track --- Vol-, Mute, Vol+, Full Screen Toggle (widens over both side panels)
    Left Side Top to Bottom
    Tool bars toggle
    OSK, not functional
    Find Points of Interest (new side pane)
    Open GPS Pane
    Reroute from Current Position
    Route Planner Pane
    Repeat Last Instruction
    Right Side Top to Bottom
    Zoom to Selected Point
    Zoom In
    Zoom Out
    Zoom to Entire Route
    Day/Night Toggle
    Route Text/Next Turn Pane Toggle
    Return to RoadRunner
  4. #34
    Nov 2007
    North Central PA
    S&T Keys
    S&T Keys found on http://www.laptopgpsworld.com/free-a...ets-trips.html. This is a tiny program that makes Streets more user, and touch screen friendly. It places little semitransparent icons on your S&T map. One is menu. This has lots of cool features. You can program in favorite destinations, and after doing so, with one click, it will navigate you to that location. The other two are a + and – symbles. This allows you to zoom in and out.
  5. #35
    Nov 2007
    North Central PA
    Complete Install Pictures
  6. #36
    Nov 2007
    North Central PA
  7. #37
    Nov 2007
    North Central PA
  8. #38
    Nov 2007
    North Central PA
  9. #39
    Nov 2007
    North Central PA
  10. #40
    Nov 2007
    North Central PA
  1. Replies: 13
    Last Post: 06-22-2009, 09:23 AM
  2. 06 Civic Mod PC Install - Pics
    By Morpheus1013 in forum Show off your project
    Last Post: 10-30-2007, 10:08 PM
