The Bybyte was a little too wide for my kit. I had to grind down the inside of the frame where the mounting brackets are held. I did this on both sides.
Next is a picture of the mounting bracket:
You can see on the pic above, I had to notch out the corners. This was due to the seepage of epoxy when I glued the trim ring on. Some of the epoxy went into the groves.
Next is a picture of the bottom mounting bracket. I had to grind some of it away to allow the Bybyte to fit.
