Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: 2007 Mitsubishi Triton
    Sep 2008
    When i forst got my truck and i started modding it i never really thought to put a carpc in it, but as i slowly ran out of other things to do i eventually decided to tackle puttin one in.
    few pics stock as a rock.
    what it looks like now.
    have done quite a bit, but seeing as its a carpc site, i better put up some pics of that.
    i used a dell Optiplex SX270 and mounted that under the front seat. powered using a carnetix 2140
    the cables run down thre the centre consol to the lilliput touchscreen in the dash.
    I took out the existing surround and modded it slightly to fit screen.
    I just added the 7 port powered USB hub today.
    Picture of the computer with seat back in.
    Reverse camera is installed in the back, i actually cut it thru the number plate as the plates in Western Australia already have a small circular symbol there.
    few more pics of other mods i have done
    boost gauge
    adjustable boost controller (and CB radio install)
    Extra switches in the dash, one for spotties, one for reverse lights, one blank
    shiny one top left is the turbo timer
    Pioneer head unit
    Kenwood amp under the seat
    Dual battery setup
    And finally this would be my favourite accessory, although it can be the most expensive...
    here is a link to my utes shed profile to another site i am on "newtriton.net"
    http://www.newtriton.net/phpbb/shed.php?view=1&id=9
    Newbie keisuke's Avatar
    Nov 2008
    Nice Install And Nice Truck
    Low Bitrate BlueOvalMacMech's Avatar
    Oct 2008
    On teh coal
    quick question, what is your dual battery setup?
    ie, isolater, battery type, etc
    "To start press any key" Where's the "any" key?
    Sep 2008
    the secondary battery is a deep cycle Century 47T
    They are joined via a voltage sensitive relay.
    It was $150 for the relay from battery world.
    cuts in at 13.7v
    cuts out at 12.8V
    Variable Bitrate bambam's Avatar
    Dec 2004
    Upstate New York
    Quote Originally Posted by tritonasaurus View Post
    Nice junk...I mean, truck!
    Very clean, nice looking install
    "Imagination is more important than knowledge." -AE
    Oct 2008
    On teh coal
    i was wondering only because if the batteries arent matched or on an isolator, you could potentially kill one faster charging the other one (without isolator they would both charge at once)
    Sep 2008
    im not entirely sure what you mean? are you saying my setup is wrong or bad?
    My understanding is that my setup is correct for me as i DO wish to have two different types of batterys. ie; a deep cycle for running a fridge and other components.
    The isolator being voltage sensitve ensures that my cranking battery ALWAYS has power, which is also good because i dont want a flat battery when im in the middle of the bush.
    read here for more info
    http://www.exploroz.com/Forum/Topic/...Isolators.aspx
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    cuts in at 13.7v
    cuts out at 12.8V
    shouldn't it be the other way around? so that when the voltage goes down on the normal battery the deep cycle engages?
    example:
    normal battery running your accessories starts to wear down, hits 12.8v the relay senses low voltage and switches over to the deep cycle battery.
    but what happens when you start the truck? does it charge the deep cycle battery until it hits 13.7v then it goes back to the main battery?
    did i get it right?
    Oct 2008
    On teh coal
    not at all. i was just bringing up the why for other readers that might not know why they would need an isolator
    Oct 2008
    On teh coal
    Quote Originally Posted by Injector View Post
    example:
    did i get it right?
    a normal setup to my knowledge is that the car and its own accessories run on the standard or primary battery. you have a second battery on an isolator for all the many aftermarket goodies on your ride. the isolator allows both batteries to charge as needed, but isolates the 2nd battery from the first.
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
