Yeah if you are checking for shorts you just want to make sure that any exposed wire isnt touching what it shouldn't be touching. You shouldn't have any exposed wire at all for that matter :P
you should be able to run the EQ off the stock harness no worries, its not like it has a small power limit set on it. Maybe the fuse was geared just for your head unit and powering the EQ off that same line has maybe added on a little extra power draw than what the fuse was geared for. Have you tried putting in a slightly larger fuse? IE if you are using a 15amp fuse, maybe try a 20 or 25amp fuse?
LinkBack URL
About LinkBacks
