my family used to own the australian version of that caprice but it wasnt availale in wood grain over here. for some reason wood grain never took off in australia
Printable View
you need 26"s to finish your project!
are you stl using this screen?
Any updates, im gonna find you on ISSF and talk to you more.
i have a 91 that used to be a show car wanna be. no car pc, just did a head unit in dash, cd changer in the glove box. 2 12" woofers in the truck and an alarm that controlled everything. with no door handles, it was the way i rolled my windows and popped my doors
http://i185.photobucket.com/albums/x...e/100_0723.jpg
As I sit here in my Wally World t-shirt, bearing a big marty moose face on it, I must say, I dig the license plate...
Sooo....
I finally found more time to get going on the new console. :juggle:
I bought enough USB cables to run the full length of the car and have power setup for the touch screen.
First fitting to get a feel for the trimming needed
http://i12.photobucket.com/albums/a2...install008.jpg
Part way there, I'm thinking the Riv shifter won't work. I had to drop the console quite a bit and it's messing uo the geometry fo the shifter, but I have a '92 Camaro shifter that may work better.
http://i12.photobucket.com/albums/a2...l/5d9a1cd8.jpg
But, I like it, it's starting to look like it was born there..
I wired up the lights, cigarette lighter (it will power my touch screen) and the power port.
http://i12.photobucket.com/albums/a2...install052.jpg
Removed the 7mm screws that held the ashtray and junk box
http://i12.photobucket.com/albums/a2...install040.jpg
the ashtray light will provide power to the console lights, since both are GM, they are even the same color. I will tap into the lighter to power and ground the power port
http://i12.photobucket.com/albums/a2...install044.jpg
power to the lights
http://i12.photobucket.com/albums/a2...install047.jpg
power to the lighter
http://i12.photobucket.com/albums/a2...install049.jpg
power to the power port!
http://i12.photobucket.com/albums/a2...install051.jpg
This where I left off. I still need the shift cable setup but it's getting there! I wanted to be done before Wagonfest West but no dice.......
http://i12.photobucket.com/albums/a2...install071.jpg
Nice to see an update on this. Keep it up!
Loving the wagon mate!
