Page 6 of 10 FirstFirst 12345678910 LastLast
Results 51 to 60 of 97
Thread: 2007 FX35 Carputer
  1. #51
    Sep 2003
    Souf Cakalack
    How did you attach the screen to the overhead console? Do you have any pics of this?
    Awesome project!
  2. #52
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Quote Originally Posted by projekakkord View Post
    Awesome project!
    I used steel bar left overs in my parts bin. You can find them easily at ACE, Home Depot.
    Then I used existing holes and bend it to shape like this, so that it fits perfectly the back of the monitor - secure enough not to vibrate a thing while driving, while still allowing to change height (about 1 1/2") and access to the monitor without having to remove the console first.
    I wouldn't fix the screen on the overhead console, it might vibrate too much, or simply break the console: at least this is the case with the FX, where the console is supported mainly by platic/metal pawls and clips. On the Sequoia, the console is screwed on, so I would be less concerned in that case.
    Hope this helps.
    RH.
  3. #53
    Sep 2003
    Souf Cakalack
    Thanks for the quick response!
  4. #54
    Dec 2007
    Danville, CA
    Well, I just added some more facilities to be able to better update and play with the carputer while the car is in my garage - without removing anything.
    1. First I had to use wired 1GbE connection simply because wi-fi is too slow. But it's a pain to reach the ethernet connection in the back of the case, so I took 1foot CAt5E patch cord, a female-female RJ45 adapter (bought at Fry's for like 2 bucks, you can find it on e-bay too)
    and did the following: plug one end of the 1ft cable to the back of the computer, the other end in the back of the above coupler; the other end is left open, secured out of sight to the front of the seat. I can just pull it from there and plug my ethernet cable easily, even in the dark, no tools necessary.
    2. Now how about the power source? You don't want to drain your battery, but you also don't want to unscrew the cables to your PSU, right?
    So I did the following: I bought two 80 amp DC circuit brakers from the mp3car store; on sale now for 9.99 (from 32.99). Why two? well, one for the positive, one for the ground to complete isolate the battery and the car from my test bench 300W ATX PSU (modded according to the PSU faq thread).
    Now you do this: you hook the + side from the battery into the BATT side on the circuit braker. On the other side, you hook two wires, one to the DC DC PSU you were using, the other one you hook to a 12 gauge stranded cable you'll later attach a molex male connector on the other end.
    You do the same with the - or ground: you attach your current ground cable to the BATT side of the circuit braker. On the other side of the circuit braker, you attach two wires, one to the DC PSU (think one, I cut from the same one I used before), another to the molex connector.
    Now you simply attach the molex connector to the ATX PSU that was your test bench, and there you have it. When you want to hook the carputer to the battery, you close the circuit braker. When you want to unhook the carputer from the battery, you press the two big red buttons, hook the molex connector to any free HD PATA connector on your test bench ATX AC PSU, and you can play with your carputer for the whole weekend: updating, synchronizing, defragmenting, ghosting, etc.
    Note that you also have TWO ACC wires going into the ACC input into your ACC connector in your DC DC PSU. One is 12v from the car, the other comes from your test bench. I removed the one from my test bench and it gets power from the wires in the molex connector that stays in the car, when the ATX PSU has power, it will give ACC power to the DSATX, M4ATX or whatever. No tools necessary.
    I hope the explanation is clear, any questions, just ask.
    Also, if you have a powered USB hub that turns on with your computer, but that it gets power directly from the battery (like this one), used for your GPS or whatever, make sure it now will be powered from the computer too (any free molex you used for the HD, Monitor, etc.), or it will drain your battery. Don't ask how I found out about this.
  5. #55
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile
    Very clean work.
    I like that .
    Good job and very nice car
  6. #56
    Dec 2007
    Danville, CA
    Thanks!
  7. #57
    Dec 2007
    Danville, CA
    Just added JoyCon to my carpc! (not without problems though, but basically it works!)
    Here we have the remote (Sony RM-X2S I took from an old cd changer) and the Joycon, pictures of it in the car to follow soon.
  8. #58
    Oct 2004
    NY
    that's cool. I picked up one of those & want to use it with the cruise control steering wheel buttons, the fx ignores all button presses on the right side of the steering wheel except the ON button when the cruise is off, plan is to uise all the other buttons for pc control, but then when cruise is turned ON, then override the pc controls for cruise.. haven't had much chance to play with it though... that sony stalk is nice & gives a lot of control options...
  9. #59
    May 2008
    Bordeaux, France
    Quote Originally Posted by RipplingHurst View Post
    Do you control RR with it ?
  10. #60
    Dec 2007
    Danville, CA
    Quote Originally Posted by pierrotm777 View Post
    That's the idea. I have it programmed it now for Centrafuse, mainly because I have a list of standard keys for most functions. With RR I have to mod the keytbl.ini.
    The app. that comes with JoyCon is strange at first, but works great! For each button in the Sony remote, I can assign a key like CTRL+ALT+SHIFT+F7; and if I hit a mode button, the whole profile can change (say from Centrafuse to RR to MCE to Google Earth, IGuidance, whatever I can assign hotkeys to).
  1. My 2006 Scion xB (portable) Carputer setup! w/pics!
    By breaker021 in forum Show off your project
    Last Post: 01-05-2007, 09:34 AM
  2. Carputer confusion- n00b needing help
    By TonyMartin in forum Newbie
    Last Post: 03-10-2006, 12:11 PM
  3. Carputer confusion- n00b needing help
    By TonyMartin in forum General Hardware Discussion
    Last Post: 03-08-2006, 09:43 PM
  4. wikipedia: carputer definition
    By pRoFiT in forum Off Topic
    Last Post: 12-31-2005, 08:32 AM
  5. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 08:57 PM
