Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
Thread: CarPC install in 2008.5 Mazda 3 5-door GT
  1. #11
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    If that Dlink is like my older one I have, that is a cradle it is plugged into. I got rid of the cradle, and used a USB extension cable. I then ran it under the molding in my back window, and had just the dongle itself exposed at the top of the window. I got really good signal compared to when I had it lower in the hatchback.
    My Fiero Build Thread
  2. #12
    Dec 2006
    Quote Originally Posted by jarred View Post
    I could hide the router, and initially had it in the cargo tray. I've also tried it in the glovebox, but it caused interference with the HD Radio module. I've found that it gets better reception being higher up in the car, and I need to be able to remove it easily to use at customer appointments.
    Some customers I do demos at do not allow you to use their Internet connections for security reasons.
    I thought you had Verizon EVDO???
    Doesn't Windows ask you if you want to connect to a network???
    Maybe I've been using Vista too long or something, but unless you have it automatically set to log onto a network, it will ask or won't do it.
    My G1 is fast on EDGE and even faster on 3G, so I don't think you would see much drop-off if you just used your cellular connection.
    Oh well.
  3. #13
    Constant Bitrate jarred's Avatar
    Sep 2000
    Stockton, CA USA
    Quote Originally Posted by djfourmoney View Post
    Oh well.
    I am using a Verizon V740 Expresscard EVDO Rev.A with a Cradlepoint CTR-500 router. This router takes care of the connection to Verizon and converts it to WiFi, so no client is necessary on the PC. The Dlink adapter connects to the Cradlepoint via WiFi.
    This also allows passengers to use my Internet connection with their laptops, etc.
    With EVDO Rev.A I get about 1.2mb down and 400k up. In some areas where they have provisioned more bandwidth at the tower, I can get over 2mb down and 800k up.
  4. #14
    Variable Bitrate bambam's Avatar
    Dec 2004
    Upstate New York
    The problem I have with a setup like yours is that my family would never see me again because I would drive 24 hrs a day never leaving my car!
    Very, very nice setup. Clean and extremely functional. Definitely one of the top installs!
    "Imagination is more important than knowledge." -AE
  5. #15
    Dec 2008
    Mazda 3 radio output lines
    Hi everybody,
    iam driving a MAZDA 3 2005 DIESEL
    i hope somebody can help me HERE.
    I have a sony xlpod subwoofer and i wanna install it. But my Problem is that i wanna connect the power amplifier to the original radio with an High Low converter. but i dont know the meanings of the output lines (colours). i was thinking about the rear speaker output lines.
    May 2008
    Is Foldershare mainly for synching PCs that are not on the same network, like if its out of range of your home network it will synch folders as long as both are connected to the internet?
    I see that you have an internet connection in your car - so you would not be on your home network.
    I'm not finding too much info on it, I guess Live Synch has replaced it already.
    http://www.downloadsquad.com/2008/11...ows-live-sync/
  7. #17
    Sep 2000
    Stockton, CA USA
    Quote Originally Posted by Minoritydan View Post
    LiveSync just replaced foldershare, but works exactly the same way. It will work either over your local network, or over the Internet. The software automatically chooses the fastest method of transfer.
    For instance, if I am in my driveway, I connect to my local network, and it does the file transfer over my local network.
    If I start driving the connection will swing over to my EVDO router, and the transfer will resume over the Internet, albeit at a slower speed.
  8. #18
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Nice install.... How do you get SlingPlayer inside of iGuidance? Thats pretty cool. Is that a RR feature?
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  9. #19
    May 2008
    Is there a reason you got the EVDO router setup instead of, say, a USB connect card for your PC?
    I'm considering getting internet in my car (I'm with ATT) but I'm not sure the most cost effective way.
  10. #20
    Jul 2007
    Miami
    I think one reason is so that other people can share his EVDO connection? Doesnt ATT limit the data connection? One thing I like about Sprint is that they are very relaxed when it comes to the amount of data usage. I went with a USB EVDO card, and it works good. Mind you it does hang when coming out of hibernation sometimes. Maybe he also usues the router for that reason, doesnt that one connect though the ethernet port? That would make it much more compatiable and less likely to act up.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  1. Mazda RX-8 Stealthy CarPC install
    By Nerve in forum Show off your project
    Last Post: 08-16-2010, 03:08 PM
  2. Just finished my Peugeot 206 Carpc + ICE install!
    By malcs in forum Show off your project
    Last Post: 08-31-2009, 04:22 AM
  3. 1999 Buick Regal LS CarPC install
    By ronjon228 in forum Show off your project
    Last Post: 04-04-2008, 06:18 AM
  4. Audi A6 custom install carpc with fingerprint recognition
    By ejdeleon in forum Show off your project
    Last Post: 07-07-2004, 04:25 PM
  5. M10000 install - 2003 Mazda 6
    By Litespeed in forum Show off your project
    Last Post: 03-08-2004, 10:45 PM
