http://www.mp3car.com/vbulletin/faq-...l-your-pc.html
http://www.mp3car.com/vbulletin/show...tegration.html
u'll need : a usb touchscreen controller(4-wire!! coz JVC uses 4-wire), a relay(4pdt), a scan converter, flex connectors/, flex extension connector,some small awg wires, soldering iron, some non conductive glue and a pair of steady hands.
The above links are the ones that i have used as references, once you pressed open on the JVC headunit(or if you don't have 12v power, theres a wheel/dial down the bottom of the unit which you can turn to open/close), then you have access to the screws holding the plastics, which secures the main flex ribbon cable. THen carefully unplug one end of the flex cable, thats one screw holding the hinges together, unscrew that and you should be able to gain access to the pcb behind the lcd. Be super cautious with the little flex cables and connectors down the bottom of the pcb, be gentle and don't twist the flex cables.
The blue 4 pin flex is the one that connects to the touchscreen controller on the PCB. Don't put all the screws back until you have tested everything. The hardest part is finding the right flex connectors.
