Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 44
Thread: Mazda Millenia, Road Runner, IGO8 PC, DashCommand YouTube
  1. #31
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    Quote Originally Posted by pierrotm777 View Post
    Hi,
    Very nice skin ...
    Is it possible to download this skin ?
    Thanks for your answer
    Thx, kudos to spidermunz (and BMW E36 skin I think) as thay actually made it.
    look at post #12 in this thread for dl...
    I've made some minor changes, specific to my needs, but its basically all there..
  2. #32
    Mar 2008
    Toronto Canada
    Quote Originally Posted by hehaha View Post
    I love Yada YD-V16 Bluetooth Rearview Mirror as well. Does the sound transmit/receive well on phone calls? I like the fact that it has Caller ID built into it.
    I'm generally quite happy as well, It may not be in the same class as a parrot but it does the job and is reliable. The caller ID is great...
    I disconnected the battery and wired the power directly, so when I turn my ignition on it autopairs, and vice versa...
  3. #33
    Mar 2008
    Toronto Canada
    Quote Originally Posted by Machinehead View Post
    First off, very nice set up. Boy you have a lot of gear crammed in there.
    I have one as well, love the sound quality. M-Audio is a little slow getting drivers updated. They were months behind releasing the XP SP3 drivers. I also got a deal on mine, $200 off ebay. Slighty used, but it works fine.
    I noticed that you're running 2 power supplies. Any particular reason that you went that route?
    Thx, yeah its a real pro card, opens up lots of possibilties, like vst and stuff, are you doing that?
    Hehe, when I ordered the carnetix I thought it would directly plugin to my motherboard, boy was I ****ed when I realized my mistake! It just so happened, though, that the local vendor (pcxcomputers) that i was getting my xenarc from had a picopsu ($45) in stock! problem solved!
    Sometimes they say things happen for a reason, well this combo has proven to be rock solid, flexible and I love the USB connection and sw that allows me to monitor and change settings from upfront...
  4. #34
    Mar 2008
    Toronto Canada
    Good luck with all of your future endeavours! An integrated hardware/software for the carPC reminds me of Apple!
    Thx man, all the best to you as well...
  5. #35
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by pcpete View Post
    I have played around with the vst stuff using a program called Console. It allows you to stack multiple vsts and get as crazy with the processing as you want. I'm not running any processing at the moment. I was having some issues getting sound out of Console at one point.
    I just happen to be running a P-2140 at the moment with a mac mini. I have a new project in the works that would do away with the mac. I like the picopsu from a form factor standpoint, but it seems undersized wattage wise for all my needs. I may go the same route you did.
  6. #36
    Mar 2008
    Toronto Canada
    He's probably not using girder. If it's anything like the Logitech Nulooq, you can set it to send keyboard commands to Ride Runner (new name get used to it).
    Ride Runner they should of named it coyote or acme front end......
    yeah, the sw can do this, but i send the key strokes to global, intercept them with girder, and forward them to rr, keys work even if rr minimized or closed for that matter (volume control etc)...
    How you liking the Nulooq, was considering it, but white just didn't fit in...
  7. #37
    Jun 2007
    It's too bad Guino already copyrighted Ride Runner, I like your names better.
    I may have to look into girder myself then. I lose control of RR when iGuidance loads until I bring focus back to RR by touching the screen or alt-tabbing as a programmed button on my Nulooq.
    I like the Nulooq, I ended up cutting it up and just keeping the top piece. The lower ring tended to chatter when I was on the highway. I use the touch ring for volume control, and then play/pause, FF, RR & gamma with the button points. I didn't like the white either, so I spray painted it with a textured black spray paint.
  8. #38
    Mar 2008
    Toronto Canada
    I'm using the last free version of girder, 3.3 something, it's around the net if you look, I can send you my girder folder with rr gml file if you need...
    I remember seeing those pics of the nulooq in black, looked pretty sweet...
  9. #39
    Newbie cano's Avatar
    Jun 2004
    ny
    wow,lov the way ur sys. I 2 got the 2140 thinking it was a power. loky a had a m2 laing around.if its not 2 much 2 ask i just got on imon remote and it says it has the keys 4 winamp in its settings , 4 the life of me i can't get it 2 work. i just downloded girder 3.29
    is there any way i could get that rr gml from u?
    sorry 4 bing so 4word.
  10. #40
    Mar 2008
    Toronto Canada
    thx man, I'm typing in my car right now, ill attach my gml file...i think it originally came with rr or digital fx skin, search your drive, you might already have it!
    you'll obviously have to modify for you system.....good luck
    Attached Files Attached Files
  1. Replies: 106
    Last Post: 02-19-2015, 09:23 PM
  2. My comprehensive guide to Road Runner and Flash
    By Sonicxtacy02 in forum RR Skins
    Last Post: 02-09-2010, 07:04 PM
  3. List of available plugins and features
    By JohnWPB in forum RR Plugins
    Last Post: 10-25-2008, 07:16 PM
  4. Help me, I am a newbie with Road Runner
    By duyusa in forum Road Runner
    Last Post: 04-02-2008, 05:08 PM
