Results 21 to 30 of 36
Thread: Isuzu Rodeo 2001 with Asus Eee Box
  1. #21
    Feb 2008
    No problems at all, really. I've always expected a bluescreen for harddrive read errors from shock movement but, never had I had any issues within the two years I've had a carpc in an offroad vehicle.
  2. #22
    Feb 2009
    I see that the eee is ssd your previous ones were normal hdd's?
  3. #23
    Feb 2008
    Quote Originally Posted by captcol View Post
    The Eee is just the "small/compact" line of Asus's machines.
    There's the Eee PC's, Netbook laptops that are very small, work great, some versions had an SSD and not a HDD.
    The Eee Box is a very small desktop, basically the Eee PC without the keyboard, mouse, webcam, etc.. just the desktop standalone computer, the newest version has native HD video decoding thanks to ATI and an HDMI output. All Eee Box versions also have SP/dif audio optical output also.
    I am not running an SSD, maybe when prices get lower, which I know they will; I'll consider switching over. Right now running a hard drive in an a vehicle I occasionally take off road, I have never had a problem at all. No skips or pauses, no corruptions and sometimes I do take that rodeo in pretty rough areas. Working great !
  4. #24
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by stevey500 View Post
    Most of the universal laptop power supplies have a built in 5V usb port at 2 amps. This will rid your reason of needing an inverter at all. I would find a different VGA splitter, heh. I'm unsure if I could handle that. I'd check out the board on the VGA splitter and see if you can bypass whatever is regulating the voltage/amperage coming into the device.
    I mean, you do what you want, I'm just letting you know my suggestions
    I have tried to find different units and all are either way to big, or they run at some crazy voltage. I did notice though that this one runs on AC power. The Adapter says AC/AC, I have never seen that before. Maybe thats why it isnt working with DC adapters. Wonder if I can change something to make it DC.
    HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
    4x 10inch Tablet
    1x Win 7 / Rear Entertainment PC
    ft/ Web Server Streaming
  5. #25
    Feb 2008
    You will have to find something that does the opposite of what a rectifier does. The rectifier is commonly found in an alternator because alternators GENERATE AC voltage, the rectifier converts it to DC voltage and then is regulated.
    I'm wondering if this will work in REVERSE.
    http://cgi.ebay.com/Power-Adapter-10...3%3A4|294%3A50
  6. #26
    Jul 2007
    Miami
    I actually have one of those on the way, but from OPUS ( I really trust their stuff). I dont think it will work in reverse though. Id there something I can do to the splitter to make it take DC? I may have to change the unit to a AC/DC unit, so I can connect to my setup.
    4x 10inch Tablet
  7. #27
    Nov 2004
    St Louis
    Links? Examples? I couldn't find one like yours since you didn't give me much to go on. Any hints or ebay links you could supply to help me track one of these down.
  8. #28
    Jul 2007
    Miami
    Quote Originally Posted by HiJackZX1 View Post
    I went ahead and ordered a new splitter, one that uses DC power, infact it has the option of using 9V or 5V. Wish I would have seen this splitter before.
    4x 10inch Tablet
  9. #29
    Variable Bitrate shrinkydinx's Avatar
    May 2005
    what are you using to convert the dvi output to rgb? ive never had good luck with converters
    carputer - done.
  10. #30
    Jul 2007
    Miami
    Quote Originally Posted by shrinkydinx View Post
    You mean DVI-D to VGA? If yes, I use a HDFury, which is made to do that conversion. It doesnt convert the MoBo though, but instead it converts the screen. All my screens in my setup are VGA.
    4x 10inch Tablet
  1. Crazy Idea
    By isphius in forum Car Audio
    Last Post: 06-22-2006, 07:10 PM
  2. F/S: JL 12w7 Subwoofer with box!!! Pictures inside
    By neema12 in forum Classified Archive
    Last Post: 08-29-2005, 08:45 PM
  3. Replies: 1
    Last Post: 07-30-2005, 07:39 AM
  4. Wanting help with an ABC sub box
    By FyreDaug in forum Car Audio
    Last Post: 07-15-2005, 04:10 AM
  5. Koolaid's 2001 Isuzu Rodeo
    By koolaidkitten in forum Show off your project
    Last Post: 04-26-2005, 08:35 PM
