Hey all,
I've finally finished building the car PC.
This is what it looks like without the lid. You can see the PSU mounted on the front and the power wires snaking around the back left:
Here's a top view with the lid off. The fan is not actually mounted or screwed to anything, it's just being held by the tight cables around it. Once the lid is put on, the fan is held tightly in place. I shook the unit a fair bit around and the fan didn't move
Back view. Note the molex connector on the left - this is where the LCD will derive its power from:
And here's what it looks like with the lid on top:
So there you have it. Now I'll have to build the relay box and wire it up between the molex connector and barrel connector for the LCD so when I switch the car off, the LCD turns off too while the PC is shutting down. I'll mount the relay inside a small plastic box and mount the said box on the back of the car PC (or I might even let it sit somewhere behind the dash).
I'll post pics of the relay box when I get it done.
LinkBack URL
About LinkBacks
