NICE!! Wish I could get mine installed...
This is my G35 using the MP3Car G35 screen. I have a Dell 8600 in a docking station in the trunk. An OBDPros connection with the car ecu and running Dashcommand. I also have a Boyo license plate mounted back up camera.
These are just night shots right now showing the screen. I will add some daytime shots later on, as I have time.
Thanks to RideRunner and DFX 4.0 for the front end and skin.
Project λ^2 (Lambda Squared or Lambda II)
[☺☺☺☺☺☺☺☺] Install 80%
Saving $ for PSU
Coming soon: freeflashstuff.net
It will be my business site, and it will also have a section dedicated to my previous and current builds.
i have a question how did you get the computer for the Auxiliary input? cuz the bose radio i have on my G35 doesnt have auxiliary
With this.
http://www.pac-audio.com/products/pr...iliary%20Input
The AAI-NIS2 works with XM/Sirius Satellite ready Infiniti and Nissan factory radios. It allows audio from devices like Apple's iPod™, VCP, MP3 players, Portable CD players, DVD players or aftermarket satellite receivers to play through the stock stereo system.
• Two AUX inputs which are selected by the SAT/Radio button on face of radio.
• Negative remote output can be used to turn on devices when the radio is in Aux1 mode.
• SWC output wire to control a device when the AUX mode is active (select vehicles only).
Compatible Vehicles:
2003-2007 Infiniti G35 Coupe Only
2003-2006 Infiniti G35 Sedan Only
2003-2007 Infiniti FX35 / FX45
2004-2006 Infiniti QX56
2006-2007 Infiniti M35 / M45
2003-2008 Nissan Murano
2004-2007 Maxima
2004-2006 Nissan 350Z
2003-2006 Nissan Pathfinder
2004-2006 Nissan Titan / Armada / Quest
2005-2006 Nissan Altima / Frontier
Latest Revision: 1.4.17
Instructions Bulletins Application Guide
Had to remove the stereo, which does require some work. You then unplug the appropriate plugs from the factory stereo and plug in to the PAC and then plug the PAC into the stereo.
I have an 07 g35 coupe manual. What did you use to mount the touch screen in the cubby? I've been looking to run my HP laptop to a touchscreen but i am a little nervous about modding the cubby. Any suggestions would be helpful. Does the MP3 car mount work in 07's?
The mp3car mount on the site is only for 03-05. They no longer have the 06-07 available, but did make one for a while. It is different than for the 07. I bought mine used from another mp3car member. Try ebay maybe. Cubby is not really modified. I took out one part that is in the garage to put back in if I sell the car. You would never be able to tell it was out of the car.
how did you edit the menu in fx4.0 ? I'm having hard time editing the menu and adding programs. and what gauges can you use from obd meter?
