Results 1 to 10 of 20
Thread: VW Golf MKIV Custom Laptop install-DVD-Radio-Bluetooth-WiFi-USB (pics)
    Dec 2007
    Hey all,
    So after having used my laptop install for about 6 months with no troubles at all now, I finally got some time to post the install process so you can see how I did it on my car.
    First Id like to thank everyone who helped me along the way, and all the info I got from reading the mp3car forum to help me get my install working just the way I wanted it.
    My setup:
    Compaq Presario V6210 Laptop with broken screen (removed)
    AMD Sempron 3200
    1gb ram
    60gb HD
    2 usb ports + 4 on Express Card
    External DVD drive
    Bluetooth Dongle
    WiFi external antenna (hacked)
    Brando USB FM Radio
    Lilliput EBY701 7" Touchscreen
    Diagram for my project:
    I apologize for the blurry pictures as they're from my cell phone...
    So here's the car:
    This was my workbench when I still had the laptop all opened up before hacking into the power button:
    Here's some acrilyc glass that I got for my screen frame, and fabricated it to fit into the dash:
    Test fitting to see if I got the size right:
    After getting the right fit, time to make the hole for the screen:
    To hold the screen in place I hacked into an old portable stereo I had laying around, cut some of the screw holders off it and superglued them to the acrylic frame:
    (the blue tape was on just to hold them while they dryed)
    Getting ready for painting:
    For the paint I used matte black automotive spray paint. It doesn't look as good on these first pictures, but the final result was pretty much good..
    The relay hooked up:
    This is a little amp I bought for the sound. I didn't care for a really loud sound, so I got this little one just to power my factory speakers.
    Now hooking up the laptop:
    And the screen:
    (I later put a 4 port hub behind the screen where I plugged in the Brando USB Fm Radio and a USB extension cord going into my glove compartment for plugging flash drives)
    Testing the DVD drive:
    (After a few tests I realized the regular 10 ft (3 meter) USB extension cable just didn't send enough power to the drive, so I had to get a usb cable with a signal repeater.)
    So with that solved, I cut a hole for it on the frame:
    This is how my trunk looked before finishing up...[very blurry pic]
    (the little blue thing on the right is my bluetooth dongle..)
    THE FINISHED INSTALL:
    The fabricated button panel... the little one powers the laptop, the second powers the screen, and the third is a kill switch that cuts power to the amp, laptop and screen, in case I dont want to turn the carpc on for some reason.
    Anti-theft cover:
    So this is it for now!! I later plan on putting a usb GPS receiver, backup cam, and maybe a OBDII reader.....but for now Im pretty satisfied with it... Tell me what you think!! Thanks all!!!
    Sep 2008
    Western Australia
    Nice install, and I'm very much liking the anti-theft cover, it looks awesome. How does it stay on? I'm wanting to do something similar for my carPC.
    Dec 2007
    thanks man!! i'm glad you liked it...
    the cover fits in the little space between the screen and the ac controls.. there's a little gap there that holds it in place. sometimes when I try to drive around with it on, it falls down, so it's usually on just when I'm parked..
    I basically cut another piece of acrylic, painted it black with the same spray paint as the screen frame, and for the finish I bought a VW rim sticker and glued it on.
    May 2008
    Beachwood, NJ
    Looks good man, check mine out too 2005 VW Jetta GLI
    Feb 2009
    Nice!!!
    Good looking.
    Newbie thenewbreed's Avatar
    Nov 2008
    SE TX
    Your project looks great. I was wondering what you used to create your project diagram page. The icons look good.
    Dec 2007
    thanks!!!
    I created this diagram based on another member's project diagram (imprezive one) I saw in one of his posts on the forum...which by the way looks great also...
    I then used a software called CorelDraw X3 to redraw the icons based on my own project. so if you're familiar with this drawing software it can be very useful!
    Apr 2007
    2 ideas
    If you decide to redo the plexi, paint behind the plexi so it keeps it shiney. Just a cleaner look
    put magnets behind the plexi so your anti theft sticks on there better
    Good build though!
    Constant Bitrate Startingline13's Avatar
    Nov 2007
    Long Island, NY
    What do you use to power the laptop?
    Feb 2008
    I hope he's using a DC-DC laptop adapter, seeing inverters in these cars makes me cringe
    Nice setup! Great job, man...
    If I may ask, what did you use to draw up your diagram?
    thanks
    -steve
  1. Jagputer Install and story log
    By JagPuter in forum Show off your project
    Last Post: 08-02-2006, 09:48 PM
  2. I'm dating a deaf chick
    By Grayscale in forum Off Topic
    Last Post: 02-22-2006, 05:47 PM
  3. Vw Golf Mkiv Install
    By kyrenia in forum Show off your project
    Last Post: 12-16-2005, 01:26 PM
  4. Replies: 2
    Last Post: 09-26-2005, 10:59 AM
  5. USB to ide adapter + Toshiba laptop dvd drive
    By carprowler in forum General Hardware Discussion
    Last Post: 06-25-2004, 12:49 AM
Tags for this Thread
