very nice! Yours is the 1st CX-9 I've seen. I'm about to do my CX-7 soon.
here is my cx-9 install, i make the face plate with bondoglass, because they don't sell the kit for this model, it's the first time i use bondo, but still looks ok.
here is factory
here is the center piece i need to make copy with bondo
here is the screen glue to the bondo
this is the mini amp i use, it's very small, it's like $35 it's 4ch with 300w
here is the screen put together painted and see how small the mini amp is
i had to cut the vga cable and the usb cable so i can bend them due to limited space
here is the cut and bent usb cable and the mini usb hub i use
here is the computer, i made the case and i fit everything in it
this is the reset switch and the relay for the screen, you got to have a reset switch if you run windows
in car test run
this is the ign wire to switch the power supply took me an hour to find it,
http://images1f.snapfish.com/2323232...7395%3A8nu0mrj
this hole is for the center speaker, but my don't have it, so i put my gps in it
http://images1f.snapfish.com/2323232...7395%3A9nu0mrj
push everything in
this is a test fit with out the dvd
and everything put back
Very good effort man.
But the screens fitting within your main bezel looks terrible. Fix it! cause you already put in such effort you might as well get it right.
Otherwise very good effort indeed. Im sure over time you will get it 100%
99' V6 Solara SE.
'05 CBR600RR
Baltimore MD.
Shuttle XPC| 512MB | 120GB 3.5" Seagate
Opus 150W PS | Rikaline 6010 GPS
7" Lilliput 619 | Centrafuse | IGuidance 3
yeh i know, i am kinda use to it now, but if you don't pay attention to it most people didn't notice it, anyway, i am waitting for the dash kit to come out, they are already working on it, should come out this year i hope, then i will raplace it. i am going to hook up the factory sterring button to the computer, i might trim it little bit by then.
yeah bondo is insanely hard to work with at first but with enough time and patience you will get it right
Those are awesome cars. I was thinking about getting one last year when the gas price were high and I opted to go with another Accord. I have a X5 at one point and the CX9 gave as good a ride if not better.
Very good effort dear.
Otherwise very good effort indeed. Im sure over time you will get it 100% result
Exporters Directory
Residential Mortgages and Re-Mortgages
