Results 1 to 10 of 10
Thread: Renault Laguna II CarPC
    Feb 2009
    Smile Renault Laguna II CarPC
    Hello world!
    I'm French, I will try to present my new install in my Renault Laguna II, model 2001 1.8l 16v
    my car:
    First I have made my config. Let's take a little case.
    For the dc to dc convertor, I use a ups card.
    it's converts 12V to 220V~
    Then I have connected my ATX power supply.
    Behind this, my motherboard, a Gigabyte GC230D (Atom 1,6Ghz, 1GoDDR, 250GO HDD IDE)
    A soundblaster Audigy in Lowprofile.
    All this in a little pc case, behind the driver's seat:
    On the left of the HDD, you can see a little card. A relay is delayed at 10sec on IGN ON and 2min at IGN OFF.
    Then I have made the mod of pin 8 on serial Com1 (+5V on pin8 when IGN ON and GND when IGN OFF).
    by the way, I have the time to start my car before autostart of the computer (by setup on the BIOS).
    When IGN is OFF, the computer hibernates, and on 2mins the +12V is cutted by the relay.
    A plank of wood later:
    Next step is installation of the 8" touchscreen lcd, a CTF800 from Cartft.com.
    disassembly of the console:
    Touchscreen fixed:
    Yeah, first boot!!
    The sound card must be connected to my player. (If I wanna listen FM tuner, and for setup of my amps)
    So I must deport it somewhere
    this way:
    Some cables..
    much cleaner:
    very much cleaner
    Thanks for your attention!
    (and I'm very sorry for my english speaking!!!)
    Newbie kensbey's Avatar
    Jul 2008
    brisbane australia
    hey zyssai, looking good! i like the idea of having the headunit in the center console, that came up very good. Screen position looks good too, does that cover fold over the screen and hide it? overall nice install
    _-_-_-_-_-_-_-_-_
    Holden FTW!
    Carpc Mk 1
    Carpc Mk 2 (in Progress)
    Feb 2009
    Yeah that's just I wanted to do
    I will made a photo soon
    Jan 2007
    Szeged, Hungary
    Ah, a Laguna2 owner! And French! And speaks English!
    Have you heard about ddt2000? A computer program, that is similar to CLIP, but it does not need an expensive adapter. I made a serial interface to that and works fine. It is not compatible with the CAN bus.
    http://forum.lagunaclub.eu/index.php/topic,92.0.html
    You can peep into different computers and set/unset/reset fault codes, settings (e.g. pressure monitoring system, ABS, settings of different methods for servo or windscreen wiper, check the pressure in the climatic compressor, enabling tempomat and many other things).
    It is far beyond the OBD2 system! It is Renault- (and Nissan and Dacia) specific! Of course, the Laguna also communcates via OBD2 protocol, but the information you could gain are limited and slow.
    If you like to have the program, I could send the link to download, too...
    We have a forum (actually, two forums) to discuss the problems about Lagunas. If you need something about it, I can answer or can translate your question. I also read the German lagunaII forum and sometimes the Romanian and the French also, but because the language barrier it is hard to interpret.
    But I'd like to know the real meaning of descripitions in ddt2000, because in spite of the English menu, it speaks mainly French.
    May I ask you some questions about it? I have a vocabulary, and my wife speaks French a little bit, but she is not familiar with electronic and mechanic expressions.
    My laguna is a 2.0 IDE model from 2002, I am quite satisfied despite of the horrifying storyes about that type of engine. OK, in the case of a sophisticated machinery, the risk of fault also increased...
    I put my car computer into the glovebox (Epia M10K) and I modified my upper display unit to enclose the 7' LCD. It also displays movies on a 17' LCD on the seat behind, to my daughter. I control it by a PIC that communicates via USB with PC. Both program running are my code. The controller is a magnetic encoder made from a rubbish HDD and cheap buttons.
    Some photos are in the 'my images' section. (together with my previous Seicento modifications
    Alopecia perniciosa
    Feb 2009
    Hello!
    Yes so long time that I'm looking for CLIP interface!!!!
    But the problem is that I have never found a good adapter, and not so expensive.
    Thanks for your link but how do you wire the odb interface with the adapter? I do not understand the wirering
    Do you have some other pictures of that?
    Thanks a lot!!
    Jan 2007
    Szeged, Hungary
    Yes, but it is very simple: the www.lagunaclub.hu link shows you the way how the ODB side is connected (12V, GND and K-line), and on the other hand the RS232 is just Tx,Rx,GND, as the PCB shows you.
    I can also send you a ready made interface, if you like it.
    Send me your address in private.
    Alopecia perniciosa
    Feb 2009
    Can you tell me where are connected the 12V, GND and K-line on the ODB connector? (which pin?)
    And the same for the rs232 connector?
    And if you can send me your interface, it would be very nice!!!!
    again thanks you because i spend many time to find how this ODB connection works and now you give me the solution!!
    Dec 2006
    Netherlands
    8" tft?
    Very nice install!
    i'm about to buy another car. i like the flap in your dash over your tft very much. how did you mount your 8" tft? did you have to cut anything?
    Low Bitrate Jitters333's Avatar
    Apr 2009
    Quote Originally Posted by DJCannonball View Post
    Very nice install!
    thats what he said lol 8" It looks like he just had to shave a bit off the right side, other than that it looks pretty clean, nice install =]
    Feb 2009
    hello!
    yesy I cutted a lot of plastic And the flap now is not automatic (I have to guid it myself)
    because before it looks like this:
    I recommand 7" tft because it's easier to install
  1. 1995 Honda Civic Sedan EX - My First CarPC
    By vladcarpc in forum Worklogs
    Last Post: 10-26-2011, 08:49 PM
  2. QUESTION about M2-160WATT AND X-TREME CARPC
    By kostas_lion in forum Power Supplies
    Last Post: 05-15-2008, 10:50 AM
  3. Renault laguna II Steeing Wheel Controls -> USB
    By d_mc_a in forum Input Devices
    Last Post: 03-23-2008, 02:18 PM
  4. MP3Car CarPC State of the Union 2006
    By SwapMeet in forum General MP3Car Discussion
    Last Post: 10-18-2006, 09:32 PM
  5. XP on CF II Drive
    By NOS TANG in forum Software & Software Development
    Last Post: 11-30-2004, 02:20 PM
Tags for this Thread
