Results 1 to 10 of 11
Thread: Car-PC install, Toyota Carina E, OEM look
    Aze
    Aze is offline
    Dec 2005
    Roskilde, Denmark
    Hi guys.
    Just updated my previous install containing a 7" touchscreen, to a new centerconsole based on a 8" 16:9 touchscreen.
    The buttons in the screen has been kept, as they will be hooked up to the car-pc, to control this...
    Hope you like the work....
    Low Bitrate SwiftDeath's Avatar
    Apr 2009
    Chicago, IL
    Nice Install
    You did a very nice job, especially with the plastic soldering. What filler did you end up using by the way?
    -SwiftDeath
    Aze
    Aze is offline
    Dec 2005
    Roskilde, Denmark
    Thank you very much for the comment.
    Is it the spray-filler you're asking to? I have used "Motip primer"...Though it is called primer it is spray-filler.
    I have tried a lot of different types. This is the best I found.
    Apr 2009
    Chicago, IL
    Fast Response
    Thanks for the response. It's always good to know what products are out there and what results they can achieve. Enjoy your new setup, I know I would.
    -SwiftDeath
    Jul 2006
    seattle
    very nice fabrication, certainly an oem look.
    dsatx in voompc 2 case <HERE>
    Nov 2008
    Ahmedabad, India
    Congrats ! Neat Install ! Happy carputing.
    Super Moderator xBrady's Avatar
    USA
    Very nicely done! Definitely looks OEM.
    Installed.
    -GPSSecure- - GPS Tracking
    Aze
    Aze is offline
    Dec 2005
    Roskilde, Denmark
    Thank you for your comments.
    Actually this is only a temporary solution, as my goal is to have 3x this screen integrated in the center dash, controlling each a car-pc.
    It just takes some time to realize, so in the meantime I'm using this setup.
    Apr 2009
    Nicely Done
    What did you do to glue the bezel and console together?
    I'm thinking of doing something similar sometime soon with my Toyota Highlander, so any info would be a great help
    Aze
    Aze is offline
    Dec 2005
    Roskilde, Denmark
    jpntaka: It has been melted together, using a soldering iron (as you can see on the pictures).
    I you want to glue it together you can use PVC glue, which will also melt ABS/PVD plastic types...
  1. Replies: 13
    Last Post: 06-22-2009, 09:23 AM
  2. Car PC Install in my 2006 Magnum SRT-8 with Mobile Monitor Mount
    By Redfox0099 in forum Show off your project
    Last Post: 02-23-2008, 03:42 PM
  3. Replies: 1
    Last Post: 11-27-2004, 06:16 PM
