Page 3 of 17 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 168
Thread: 2007 Honda Civic Si Install Completed. Updated [4-4-2010]
  1. #21
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by Bxsteez View Post
    I used some generic usb dongle and it works with centrafuse it just eventually freezes the entire system. I changed my xm port to 21 and i still have the same issue. I'm going to try and run my system with them both unplugged and see if ever crashes. The problem is that there is no set time it crashes so it may run fine for days and that won't definitively tell me anything.
    Did you change it under device manager and CF's settings? I would try it without... Also did you try it without CF and rather the software supplied by Mitch?
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  2. #22
    Dec 2007
    Iowa
    This is one for the history books. So i tried to force this thing to fail with neither plugged in but still trying to excercise the virtual com ports just to make sure it wasn't a registry glitch. I finally made it fail with no usb devices plugged in. So from there i thought damn maybe its my hardware, specifically the motherboard. Then i tried to think back and remember what i had done besides update centrafuse. I installed Intel Graphics Drivers with that accelerator program. I uninstalled all that crap and went back to my custom drivers from cartft site. So far nothing has failed but i haven't really been able to test it for long. I've plugged everything back in and everything is working perfectly right now. I'm gonna keep trying to force this setup to fail
  3. #23
    Jul 2007
    Miami
    HAHAHAHAHAHA, thats like with my MoBo. If I use the ATI drivers from ATI, the system acts really bad. If I use Windows drivers, all is good. You know in the end its always the d@mn graphic drivers.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  4. #24
    Dec 2007
    Iowa
    Man i would've never thought bad graphics drivers would freak out the system like that but damn i guess u live u learn. No matter how much software integration you do you will still hit road blocks... Hopefully i've destroyed this block
  5. #25
    Dec 2007
    Iowa
    Well of course now that i've solved one issue i found another one that requires a ton of work. Turns out my screen must be installed too tight or something cause my screen is being pressed when i'm not pressing it. Its happening at the bottom middle. I can't think of anything else that would cause this one.
  6. #26
    Jul 2007
    Miami
    Its not that hard. The screen must be too tight on one side. Could also be something is stuck in the corner of one side. Be glad you dont have my type Bezel, its such a b!+ch to take out.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  7. #27
    Dec 2007
    Iowa
    Here are my amps. I'm gonna need a box before i install these. They are way bigger than i thought they were gonna be so we will see what i figure out.
    SUB AMP
    Mids and Highs AMP
    BOTH AMPS TOGETHER
  8. #28
    Dec 2006
    Ummm how come you didn't opt for Alpine PDX series? Class D and TINY or Sony's Slim Class D's. Laugh if you want, they sound good, put out great power and are dirt cheap.
    Otherwise, cut your nails mane
    Nice install...
  9. #29
    Dec 2007
    Iowa
    The alpine pdx series was too expensive for me. Haven't seen the sony slim class d's. I'm not a fan of sony amps,speakers or subs but i wasn't expecting marvelous sound because of my factory speakers. The two amps together cost me like 250 bucks.
  10. #30
    Jul 2007
    Miami
    Quote Originally Posted by djfourmoney View Post
    Nice install...
    I agree, one thing that drew me to the PDX is that its smaller and its stackable. Kimota uses them in his car and they are mind blowing.
    On the website they go for $500.00 - $550.00, but I have seen them go for $250.00 - $290.00 which is amazing for the sound you get. The Pioneers are nice, almost the same size of the PDX, just not stackable. Before you bought your amps, did you measure? The way I did it is I got measurements then built a card board version, since I do not have the amps yet.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  1. 2007 Scion TC Install
    By deeznudts in forum Worklogs
    Last Post: 06-10-2008, 12:03 AM
  2. honda civic si 05 haTCH sub install help!!!
    By hondacivicsi123 in forum Car Audio
    Last Post: 04-02-2008, 06:33 PM
  3. 94 Honda Civic Si DJ.Esco Build v2.0
    By djesco in forum Worklogs
    Last Post: 02-24-2008, 07:09 PM
  4. 93 Honda Civic Dvd/Mp3/Lcd Install
    By civicduties in forum Show off your project
    Last Post: 01-17-2004, 04:11 PM
  5. install on a 95 honda civic
    By schrodos in forum General MP3Car Discussion
    Last Post: 11-21-2000, 05:43 AM
