Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Mitsubishi lancer 9 Car PC
    Oct 2008
    Lightbulb Mitsubishi lancer 9 Car PC
    Hello..
    want to show several pictures of my Lancer 9 carpc.
    I have carpc in my car arround half of year.
    My old motoryzed lilliput GL701 - is not so good idea for carpc and I've decide to rebuild HVAC panel.
    Before:
    first step:
    I have use lilliput 619GL for project.
    Result:
    Jan 2008
    Dartmouth, MA
    Awesome setup, I really need to learn how to fabricate things.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Low Bitrate willmeyer's Avatar
    Feb 2009
    DC
    Wow, great fabrication by the way. Nice work, looks great.
    Variable Bitrate csfile's Avatar
    Feb 2009
    Quote Originally Posted by PaulF View Post
    same here
    looks way better than the before pics
    And
    And is offline
    Jan 2009
    I can't see your pictures
    I have a question, I have an 8 and I fitted my PC in the boot, where did you take your ground from, mine is of the rear seat mount at the moment, but I have a very noisy ground in the car that seems to keep rebooting the PC, sounds as if your solved the problem if only I could see how you did it
    cheers
    Andy
    Oct 2008
    Quote Originally Posted by And View Post
    cheers
    Andy
    maybe something wrong then you try to see pics. pls try again.
    I've power my pc and monitor directly from battery with separately wires (+ and -). -It is main rule in instalation.
    I've use only ACC from car in my project for switch on of pc and monitor.
    Sorry for my english.
    I've fight all noises.
    Pls see picture:
    Oct 2008
    Sorry for my comments. it's on russian. I will translate it ASAP.
    системник собрал из корпуса десктопа.... инструменты - ножницы по металу и заклепник...
    уж очень хотелось полноценный ПК микро-АТХ, а не mini-ITX...
    Конфигурация: CoreDuo 2.2Ghz, 1Gb RAM, 160Gb HDD, мать - micto ATX, БП M2-ATX, bluetooth, GPS-BU-353, Wi-Fi, GPRS/EDGE internet modem, WinXP SP3, Centrafuse, iGO8.
    Звук подключил через AUX- магнитолы Пионеер. Играет отлично...
    На панельке снизу разместились кнопки RESET, дополнительная кнопка отключения подачи ACC на БП (если я не хочу чтоб комп включился), индикаторы-светодиоды Power и HDD.
    Сразу после установки появились наводки-трески от работы винта и вой генератора в динамиках....
    Пришлось перечитать кучу тем на этом и соседнем форуме... вобщем помогли все решить рекомендации от Chip c compcar.ru (кста все рекомендации от него только по делу...удивляюсь его познаниям в этой и смежной областях и как ему на все время хватает..)))))
    Проблема решилась применеием в цепи питания кондера в 100000мкф и ферритового кольца, выдернутого с згоревшего атх-го БП.
    Кабеля проложил правильно с соблюдением тех же рекомендаций.
    Oct 2008
    размещаем ЖПС приемник и ЖПРС - модем для инета.... ксатити скорость загрузки порадовала...
    и сама навигация - классная вещь.... не сколько доверяюсь ей, сколько помогает узнать по какой улице сейчас едешь (не нужно искать таблички)
    как не крути, а тачскрин не заменит клавиатуру в определенных ситуациях... посему была приобретена такая вот с трекболом...
    скажу честно- держал в руках и меньшие по размеру, но по эргономичности и удобству пользования - эта лучшая. ну и место в салоне я для нее определил слева сидения...там она отлично помещается....
    Под камеру заднего вида вырезал отверстие в крышке багажника...(как выяснилось потом - зря. есть камеры получше и с креплением попроще).
    Камера уже вторая. первая разбита была. у второй недоволен цветопередачей и вообще качеством... буду менять...
    Хочу вот такую:
    Для установки нужно просверлить лишь одно оверстие диаметром 6мм .... ну и надежность крепления у камеры нормальная (от пионеров) - прилегает плотно и смотрится как штатная...
    также установил маршрутную камеру
    но тоже буду менять..как оказалась она чернобелая, что не очень поможет в случае чего....
    Поставлю такую:
    она цветная, и с опцией отключения зеркального отображения.
    только стала делема чем видеозахват делать...
    сначала поставил отдельную DVR PCI карту. причем не дешевую - 240у.е. такие применяются в видеонаблюдении и можно подключить 4 камеры. она не загружает проц и обрабатывает видео сама...особенно хорош в ней софт - с большим количеством опций тонкой настройки.... но вылезло одно НО - софт запускается лишь с минимальным разрешением выше 900 (точно не помню), что не применимо с моими 800*600....
    буду что то думать..
    And
    And is offline
    Jan 2009
    hi thanks for the quick reply, so just to clarify you have run a new ground wire from the battery? and the put a capacitor across the + and - to smooth it out?
    I can only see the image in your last post and not the ones in the original one though still. are they hosted somewhere else?
    Andy
    Constant Bitrate Pathos's Avatar
    Jun 2004
    St. Louis Mo.
    Great job on the monitor housing.....what is the blue stuff you formed the shape of the housing with?
    "A rose by any other name is still a flower"
  1. Replies: 22
    Last Post: 12-17-2009, 07:21 PM
  2. 2004 Mitsubishi Magna VR Car PC
    By MitchellO in forum Worklogs
    Last Post: 01-01-2009, 12:12 AM
