Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 37
Thread: Mercedes benz w203 2005.
  1. #11
    Newbie Djole501's Avatar
    Jul 2009
    Quote Originally Posted by bad_luck View Post
    ISn't VNC something like Remote administrator ? Where you can access a pc thru the internet ? In that case... You must have something like a network in your car? Or not ??
    Of course, i use the built in wifi adapter in the eee, removed the antennas from the case and stuck them on top of the glove box. You can get a cheap usb card for your setup if you don;t have wireless.
  2. #12
    Jul 2009
    Small update
    Found a good place for the on/off switch but lost the cigarette lighter which isn't a problem. The switch can be extended from the eee with 2 wires...
  3. #13
    Jan 2006
    I love the power switch idea! So, what other tricks do you have up your sleeve?
  4. #14
    Aug 2008
    he can u tell me what you used for power
  5. #15
    Jul 2009
    Quote Originally Posted by jatt1188 View Post
    I just used a normal car charger for eee.
    @all
    Thanks for the positive reactions!
  6. #16
    Newbie zvjer's Avatar
    Aug 2005
    Very nice, I like it!
    I was thinking a LOT about using the EEE, but 7" is just too big for my Opel Corsa. It must be 6.5", but that's pretty much solved right now.
    Where did you buy the touch panel? Which model is it?
    Opel Club Croatia
    Opel Corsa OPC
  7. #17
    Aug 2009
    Excellent job overall.
    One question though:
    Why didn't you install 7" VGA touch screen and VGA output of EEE instead of messing with soldering?
  8. #18
    Jul 2009
    Quote Originally Posted by zvjer View Post
    I grabed one from ebay, the controller has a USB hub built in so i used that to connect gps and camera to the touchscreen connector.
    Quote Originally Posted by Maine_Coon View Post
    Well the first reason was my budget, this way there was no need for a new screen, just a touchpanel. Other reason is that EEE lcd seems to be brighter than regular lilliput screens. I can not confirm this since i don't have a lilliput but the screen is very readable in sunlight.
  9. #19
    Aug 2009
    Quote Originally Posted by Djole501 View Post
    Like I said, excellent job, don't take my post as a criticism. I am not that good in soldering and I would probably fry my EEE before long. Properly modded double-din Lilliputs (double-din) are going for about $250 on fleebay which is about twice the price of my EEE 701.
    I also looked at this guy project: http://www.benzworld.org/forums/w208...mmers-gps.html You Benz owners might find it interesting.
    I have Mercedes CLK 320 convertible and I am working on my carputer project based on EEE too. Hopefully I will present it here soon. It will be quite different from yours though.
    One more question: where did you get matching grey leather? My car's interior is grey too.
  10. #20
    Jul 2009
    I would recommend extending a laptop lcd cable this way but it's doable if you feel very confident with soldering. It's a cheap option if you use eee anyway.
    My interior is actually black, maybe the light and the photos make it look grey. You can get leather at local stores. You can go for vinyl or real leather, i used real leather, had some left from some other interior things i have done.
  1. Mercedes Benz C-Class W203 Sedan Install
    By wuzzaap123 in forum Show off your project
    Last Post: 07-22-2010, 10:43 AM
  2. Mercedes 2005 C230 Kompressor CAN bus Questions
    By ImInSanDiego in forum General Hardware Discussion
    Last Post: 03-12-2010, 12:01 AM
  3. Mercedes 2005 C230 Kompressor CAN bus Questions
    By ImInSanDiego in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-27-2009, 12:28 PM
  4. Mercedes Benz CLK 430 Carputer Install
    By MoFo in forum Worklogs
    Last Post: 10-12-2008, 08:47 PM
  5. Where to DL old version of RR?
    By accentsound in forum Road Runner
    Last Post: 07-12-2005, 01:51 AM
