Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: 1981-1993 Dodge custom crew-cab truck
  1. #11
    Constant Bitrate mstaedt's Avatar
    Dec 2007
    The HD tuner is under the front passenger seat and the amps are under the rear seats, but I don't have any pics of those.
    Future plans are to replace the HVAC controls with a Fusion Brain setup. I also want to hook up the headlight switch and dash light dimmer to the FB and then control the gamma/brightness of the monitor automatically with the lights.
    Thanks for looking!
    Project completed! (almost)
    My Truck as featured in Custom Classic Trucks magazine.
  2. #12
    Jul 2009
    Your truck arouses me, sir.
  3. #13
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Modern vintage - FANTASTIC! Better than from factory - NICE!
    For the future you may think about molding-in the monitor sorta like this (mine) 1981 F-100.
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  4. #14
    Dec 2007
    Quote Originally Posted by treetop777 View Post
    That looks really good! I was kinda stuck with the hole that was left after I removed the HVAC controls and the cheesy Dodge "message center" that was there. Plus I was in a hurry to get it finished before Chryslers at Carlisle car show. I have another cluster bezel I can play with, though...
  5. #15
    Jul 2009
    Don't know if I would have mounted a PC directly above a Bass Tube but I'm certain the Bass would shake it no matter where you mounted it. :P
    That is a very clean and professional looking install too. I like the metal enclosures for the PC and corssovers / relays above the Bass tubes.
    Very nicely done.
  6. #16
    Dec 2007
    Quote Originally Posted by pcguru View Post
    Very nicely done.
    Thankyou.
    I don't think the Bazookas are big enough to do much damage, especially since I don't really crank them up that much. Plus, I'm not too sure what COULD get damaged since the HD is solid state.
    So far it's all hanging together!
  7. #17
    Jul 2009
    Well any vibration is no good for electronics, but your right it is probably so minimal that the vibration from driving causes more stress on the components then the bass tube.
    But you never know there are large speaker magnets in those tubes and those magnetic fields could cause issues down the road (no pun intended) but mostly likely they would only cause issues with the harddrive. Being that you used a SSD you should be fine once again.
    Nicely done once again. I hope my install looks that good when I finally fininsh.
  1. Replies: 1
    Last Post: 02-19-2008, 09:47 PM
  2. jjnit's 2005 Nissan Frontier LE Crew Cab
    By jjnit in forum Show off your project
    Last Post: 04-01-2007, 01:43 PM
  3. 2003 Dodge Dakota Club Cab problems
    By MisterMorse in forum Newbie
    Last Post: 10-15-2006, 10:54 PM
  4. FedoraCore4 - Wireless issues?
    By frederic in forum Linux
    Last Post: 02-01-2006, 09:09 PM
  5. Custom enclosure for a Dodge Neon, Amp, & Subs
    By tejohnson in forum Classified Archive
    Last Post: 06-17-2002, 01:38 PM
