Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: 2003 Acura RSX- Sonic's Ride
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    I finally took the time to show off my project
    I drive a 03 Acura RSX Coupe... Picked it up about a year ago with < 20,000 miles on it and couldnt pass it up
    The Specs on my computer installation are as follows:
    Intel DG45FC Motherboard
    E8600 Core 2 duo 3.0ghz processor
    2Gig Ram
    Samsung 320GB Hard drive
    m2-ATX (soon to be replaced!)
    7" 2008 LED Backlit Lilliput 629
    Onboard HD Audio
    XMD-1000 w/ mp3car adapter
    Verizon u720 Broadband card
    Elm327 USB OBD-II reader
    Bu-353 GPS Receiver
    Directed HD Radio Tuner
    SpaceNavigator PE for front end control
    Fusion Brain for temp sensor and relay control
    Slot-Load DVD player
    Carnetix p5usb hub
    Carnetix CNX-P5V 15 Watt +5V Regulator
    Unnamed 7 Port Hub
    Bluetooth Dongle
    Apple mini bluetooth keyboard
    Audio Specs:
    Rockford Fosgate P1S410 subwoofer
    Hifonics Zues ZX8000 5 channel amp
    Rockford Fosgate 3Sixty.1 Processor
    Stock Clarion speakers
    The majority of my computer hardware is installed on the rear of my subwoofer box.
    The computer is installed in a Morex 5677 case. I cut the top of the case to install a grille for the processor fan. Initially i was concerned in upgrading to the DG45FC over my previously installed D201GLY because of power and heat but the new motherboard and all components still run clean on the m2-atx. the carnetix point-of-load device is even overkill in my installation. Also installed on the sub box is the Carnetix p5usb hub and my RF 3sixty.1. The Hifonics amp rests on top of the sub-box. I was lucky enough to find the amp on craiglist a few weeks ago and i am very impressed with its features. It also allowed for an easier install that worrying about wiring and tuning two seperate amps.
    In the front of the car the lilliput is mounted to a custom bezel i just recently re-bondo'd.
    The pictures dont do much justice.. but the lilliput has practically no glare from the drivers position because of the way the factory dash is molded to the drivers side of the car. The XMD-1000 and the directed HD radio are tucked neatly behind the screen. Just below the screen the factory cigarette lighter has been replaced with an MP3car usb plug.
    and just to the left of that resides my elm 327...
    Under the e-brake and placed nicely at the drivers right hand is my SpaceNavigator device that controls volume, voice recognition, and media playback. I can also set the device to control my mouse pointer if need be.
    The glovebox houses my Slot Load DVD and a generic 7 port usb hub which is connected to the devices in the front of the vehicle.
    Lastly, my Andrea Array microphone for Voice-recognition and hands free calls through my cell phone is hidden on my gauge cluster.
    Not the cleanest install, but everything works and works well!
    Live mp3Car Facebook Chat
    Jan 2004
    looks good, how's the andrea microphone? I put in a labtec desktop analog and tested out my bluetooth phone and it gave off a lot of echos. I'm wondering how does your andrea sound card/microphone hold up?
    Woodbridge, VA
    Blog Entries
    32
    the andrea mic works beautifully unless the windows are down. I'm pretty sure its USB adapter cancels out the ECHO i've heard with other mics. I posted a full review of the andrea in the hardware review forums awhile back. Check that out.
    Low Bitrate willmeyer's Avatar
    Feb 2009
    DC
    Looks great, very similar install of the SpaceNav PE to mine (in my sig). I like the way your screen looks, seems like a good spot for the anti-glare situation, definitely.
    Variable Bitrate TeamRSX's Avatar
    Nov 2007
    Ottawa, Ontario
    Hey Sonic,
    Nice install. I also drive a rsx and really like it.
    Your dash kit looks good man. Looks like you really nailed it on the colour. Matches great.
    I just have a question for you. In my install i am getting very little interference in the monitor, not noticable during the day, but at night time you can see it a bit. Probably due to the fact the vga is too close to a power wire somewhere.
    Where did you run your power wires/data/speakers/vga wires? SInce your computer is also in the back just wondering how you have it setup.
    Again great job man..
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by TeamRSX View Post
    Hey Sonic,
    My power wires run down the left side of the car under the carpet and all usb/rca/etc run down the right side. There's still a small margin of flickering in my monitor though. Its probably because there is no shielding between the back of my monitor and the ECU of the car.
    Your car is actually the one that inspired me to start this when i bought the rsx. I LOVE the way you did your bezel.
    Nov 2007
    Ottawa, Ontario
    Quote Originally Posted by Sonicxtacy02 View Post
    Thanks for the info. The problem is i am a perfectionist, like most ppl on this board, and the smallest things bother me.. haha, but i'm not about to pull all the wires in my car for a small amount of interference that i can barely notice.
    Thanks for the compliments, your dash kit looks very close to the way mine looks. I really like how you hide the buttons on the bottom of the bezel. This way it looks so much more cleaner. Thats exactly how i have mine....
    Apr 2008
    USA
    Is it necessary to fabricate the bezel? Reason why I'm asking is I have no clue how to use bondo so was hoping I could get away with mounting the screen in without any complicated fab work. Looking at this as a way to mount the screen in my dash this as the dash kit. With the two items I just listed, can I expect a Plug-n-Play experience or will I still have to do some fab work.
    Great job on your carputer!
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by crow610 View Post
    you certainly can just hide the monitor behind the bezel but its gonna cut off a portion of your display.
    Apr 2008
    USA
    Oh really? Can you recommend any places that will fab the bezel?
    Also, what are you doing about getting AM/FM on your carputer? I was thinking of teathering my phone with the carputer and stream all my music but may still want/need AM/FM.
  1. 2003 Acura RSX System
    By rsxer63 in forum Show off your project
    Last Post: 01-09-2009, 06:21 PM
  2. 2004 Acura RSX Type-S turbo - Mac install
    By Fallout in forum Show off your project
    Last Post: 05-16-2008, 05:16 AM
  3. Sonicxtacy02's Acura RSX Install
    By Sonicxtacy02 in forum Worklogs
    Last Post: 03-16-2008, 12:16 PM
  4. 2003 Civic CarPC (AIR RIDE)
    By kumanan in forum Show off your project
    Last Post: 03-15-2007, 11:20 PM
  5. 2003 Acura CL-PC
    By juve021 in forum Show off your project
    Last Post: 04-10-2005, 12:15 PM
