Results 1 to 10 of 13
Thread: 2003 ford ranger
    Feb 2009
    2003 ford ranger
    computer is nothing fancy just an old micro atx gateway desktop from around 2003 powered by a M2 atx 160w and put into a plexiglass box. Computer was free thats why i went with it.
    monitor is a xenarc 700IDT that i gutted out of its shell and mounted into my dash.
    sorry for the crappy cell phone pics.
    computer is stuffed behind drivers seat. not much room in this tiny pick up
    runnin xp
    for a front end im running RR with the new eLite skin
    mouse and keyboard im running GRemote software that allows me to use my HTC touch pro 2's keyboard and gsensor (or touch screen) as a mouse and keyboard. pretty sweet i think.
    also can tether data from my phone.
    also considering trying out a slingbox to get cable tv on this thing.
    nothing fancy but it works well and im happy with it. let me know you think
    Feb 2009
    im having some trouble with my audio as in there is none lol
    i have my amp hooked up to a usb sound card and have my speakers wired up 2 channel monobridged since i have no radio. my amp is turning on so its not a ground issue.
    any ideas why im not getting any sound?
    Maximum Bitrate SjLucky's Avatar
    Jul 2003
    Meridian, Mississippi
    does it have an on-board sound? IE does it have audio ports on the mother board? If so then it could be that winamp is looking to it or output. If not, then check your volume levels in windows mixer. Try using an mp3/cd/portable media device in the amp just to test it to make sure its not the problem. then try using headphones on the pc to making sure its outputting audio. Pretty simple stuff to check out.
    Did you make your own bezel for that screen?
    Its funny how much your dash looks like mine...
    Quote Originally Posted by menudude View Post
    thank you all for your help minus the useless post by sjlucky...
    Feb 2009
    well i got one speaker to play and it sounds pretty damn good. turns out it was a speaker wire issue. one of my connections popped out. ill have to look into the other side still.
    the bezel is factory i just had to trim out the back out of it a bit to accept the monitor.came out pretty good tho i think
    Jan 2009
    How did you mount the screen in to the bezel. I have an 01 Ranger, and I am stuck on how I am going to mount my screen into my bezel.
    Dec 2008
    you started with the most important part- the perfect truck. good job
    Feb 2009
    I actually did not mount it in the bezel... i trimmed out the bezel to accept the monitor then with bezel back in the dash the frame of the dash slightly pushes on the back of the monitor to hold it in place and hasnt moved since i put it in there.
    Jul 2007
    Seattle, Washington
    Do you have an amp? I just wanted to see where you put yours.
    Also, do you have any more pics of how you put your monitor into your dash? I'm still deciding on how to properly mount mine. The problem that I run into are the two screw that come up where the climate controls are. I'm afraid that they might hit the screen.
    Dec 2008
    amps are perfect under the seats of these trucks. there are even drainholes under there in the body for you to run power cables to. no worrying about going through the firewall that way.
    Feb 2009
    Quote Originally Posted by thebigthn View Post
    yes the amp is located behind the passenger seat above where the jack is...
    when i bought my truck those 2 screws were actually missing, but the bezel stays in the dash perfectly fine without them.. no sorry i never took pictures when i was doing my install.
  1. 2001 Ford Ranger Edge 4x4
    By thebigthn in forum Show off your project
    Last Post: 10-31-2010, 10:57 AM
  2. 2003 Ford Ranger FX4 Install (Lots of pics)
    By tbird2340 in forum Show off your project
    Last Post: 10-12-2009, 11:21 AM
  3. Possibly FS: 2003 Ford Ranger FX4 - LOTS OF MODS!
    By tbird2340 in forum Classified Archive
    Last Post: 07-05-2005, 11:59 AM
  4. 1996 Ford Ranger - Suggestions on Sound Setup
    By Mrbmw99 in forum Car Audio
    Last Post: 11-10-2004, 02:47 PM
  5. 1996 Ford Ranger w/M10000 & Xenarc
    By parawing742 in forum Show off your project
    Last Post: 01-30-2004, 07:37 PM
