Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: '07 Focus INSTALLED!
  1. #21
    Aug 2008
    Quote Originally Posted by TechnoTherapist View Post
    If you look at the pix on the first page, the third pic down, which shows the connection plate of the motherboard, you'll see two RCA audio ports in the upper right corner (next to the LED lights). Those are connected to the CD audio ports on the mobo. From there, it's a simple RCA cable from the CarPuter to the Amp.
    Cy
    yea thts what i wana know how r they connected to those RCA audio ports is there something in between motherboard's audio jack i mean any special sound card or something or is it straight using 3.5 pin ?
  2. #22
    Feb 2008
    Quote Originally Posted by jatt1188 View Post
    You can easily do it straight using 3.5 pin. In this case, I soldered the RCA positive lines to the 3.5mm positive line, then ran the ground lines to the system's ground. I did this so I could still use the 3.5mm plug for standard desktop speakers when I'm working on it at my computer desk. Basically, it'll push audio through 3.5mm and the RCA ports at the same time. You can easily use a 3.5mm to RCA adapter for the same results.
    Cy
  3. #23
    Aug 2008
    thanks a lot
  1. 8" screen, will it fit in a 07 focus?
    By clutz2516 in forum LCD/Display
    Last Post: 01-30-2008, 03:50 PM
  2. Replies: 1
    Last Post: 07-06-2006, 05:10 AM
  3. installed line amp in 05 xterra and no sound
    By 05-se in forum Car Audio
    Last Post: 06-12-2006, 12:51 PM
  4. LOG: Software installation and setup
    By d_sellers1 in forum Software & Software Development
    Last Post: 06-08-2006, 10:11 PM
  5. Keypad navigation and focus
    By djmickyg in forum Road Runner
    Last Post: 02-22-2006, 02:59 AM
