Results 1 to 10 of 10
Thread: 2006 VW Jetta CarPC
    Newbie mshowman's Avatar
    Dec 2009
    Parker, CO USA
    2006 VW Jetta CarPC
    After gathering the parts for a few weeks I installed my CarPC in my 2006 Jetta over the weekend.
    I initially fabricated by own bezel using a double-din installation kit and the headrest mount that came with the monitor but didn't really like the way it looked so I switched to the bybyte bezel. The VM7000 was slightly bigger than the frame and glued inside it's housing, but after a couple hours with a dremel, and xacto knife and a glue gun I got it to work and still look normal.
    Initially after hooking up the monitor to the accessory 12V I was getting vertical bars on the screen. I fixed it by running its power from the 12V bus on the PC power supply (along with the XM USB interface board).
    The PC is based on a Zotac single Atom board in a mini-box ITX enclosure (+ 160GB 2.5" SATA HDD and 2GB RAM). It's running Centrafuse on top of Windows 7. I'm using the MJS xmdirect USB interface for XM and an earthmate BT-20 GPS I had.
    Sound is through an Alpine 4-Channel amp to the factory speakers. I spent several hours messing with getting the 4 channel sound to work in Windows (No bass whatsover, Centrafuse stability issues with the Realtek drivers VS windows drivers, etc) before I gave up and used a Y-splitter into a single audio output on the PC. It sounds great though, and most audio is 2-channel anyway though.
    I tried to use an ADS USB FM tuner but it won't run natively in Centrafuse under Windows 7, and the workaround I found led to Centrafuse crashing constantly. Reception also wasn't great when it did work.
    Next phase is to add an HD radio tuner, and get a better GPS (probably the BU-353). I'll probably eventually upgrade to a better, transreflective touchscreen monitor as well as switch to an SSD hard drive.
    Parts List:
    http://www.mini-box.com
    - M350 Universal Mini-ITX enclosure
    - M3-ATX Plug-In Smart car PC PSU
    - Zotac ION B-E mini-ITX Single Atom N230 Motherboard + CPU
    - VM7000 7" touchscreen
    http://store.mp3car.com/
    - MJS-XMD2 XM MiniTuner USB PC Interface
    http://www.thenerds.net/
    - Scosche VW2317B Stereo Installation Kit
    - Scosche VW01B Wire Harness
    http://www.mo-co-so.com/
    - Double DIN Lilliput 701/629 Monitor Frame
    http://www.bestbuy.com/
    - Audiovox XM Direct Kit
    - Alpine 200W 4-Channel AMP
    + Cables, speaker wiring, etc
    Nov 2008
    Nice I want to do this to my Touareg but i'm trying to figure out how to keep my factory radio and connect my mac mini
    Jan 2008
    nice work, very clean install!
    Dec 2009
    Parker, CO USA
    Quote Originally Posted by m35x_touareg View Post
    I was looking at this but decided to go the integrated route:
    http://www.scosche.com/products/sfID.../productID/513
    This will let you add an aux input to the factory radio (appears like a CD-changer to the radio) and let you connect to any stereo audio source, eg. a Mac Mini.
    Nov 2008
    Quote Originally Posted by mshowman View Post
    Thanks this is just what I needed. So far the ony thing I have is my mac mini (first generation) Now I need to find something that helps me use my iphone (talking) hands free.
    Nov 2008
    How does your system sound without a real radio?
    Dec 2009
    Parker, CO USA
    After some tweaking, it sounds better than it did with the factory radio. With the standalone amplifier and the equalizer in Centrafuse you have more granular control over the sound.
    Dec 2008
    I am running a similar setup in my '08 R.
    how does win 7 do on the atom 230?
    Dec 2009
    Parker, CO USA
    Windows 7 runs beautifully on the Atom. I wasn't expecting much outside basic audio through Centrafuse, but Windows 7 definitely does good job of getting the most from lower-end hardware.
    The startup time and running basic apps is comparable to my home computer running Windows 7 with an AMD Phenom X3. I definitely wouldn't try to run any games on an Atom system though.
    Feb 2006
    Melbourne, Australia
    Nice, and clean
    I like the way you fitted your LCD, goes well with the interior.
    Wrt the case - I'm also using one of those Mini-box M350's, and they work very well - keeping my Zotac system nice and cool.
    Keep up the good work, loving it.
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
  1. Proposed setup for 2006 VW Jetta
    By waldo867 in forum Newbie - Proposed setup
    Last Post: 05-12-2009, 09:05 AM
  2. 2004 VW Jetta GLI - CarPC install
    By dustin in forum Worklogs
    Last Post: 07-25-2008, 12:55 PM
  3. VW Jetta W/ Monsoon System...
    By VeeDubBORA in forum Newbie
    Last Post: 03-04-2008, 01:23 PM
  4. 1997 VW Jetta GLS Install
    By SiGmA_X in forum Show off your project
    Last Post: 08-22-2005, 04:36 AM
  5. EPIA 800 in a VW Jetta 1.8 TURBO
    By samc in forum Show off your project
    Last Post: 10-27-2003, 06:18 AM
Tags for this Thread
