The problem is nothing major but aggravating. I found myself running to the front trunk to reset the power to my pc four times while I was at the beach for three days. Apparently the pc would get stuck trying to power down for the hibernation.
Printable View
My new pc reset controller. After looking over the car I don't plan to use this in its current state.
After looking at the panel, I think the easiest way to tap into it is through the button switch. I still have two dummy switches on the center console unused. If I need to I can plug in two rocker switches to do the four functions (each rocker has two buttons).
Another project ? Hehe:high5::high5:
sad but true. Not to long ago finished my arcade cabinet. after i finish the car I will start on server.
I have one of those 4 switch devices also. You are going to use it with a relay? Otherwise that 12V going through the power switch.
Why not just run a reset and power switch directly from the mobo? I have them for each computer going to the arm rests of each seat.
To be honest i saw that panel at autozone a while ago. i thought it would be cool if i could use it. When i had that beach problem that was the first and only thing that popped in my mind. Thanks for the question/tip/reminder about the reset power switch. I will test that first to see if that's works for me.
Its more of a power problem than a reset problem. the pc power cycle is setup to shut down after an hour. sometime the cycle will hang up and not shut down. I will use a rocker to turn on/off the pc main power and rewire the idiot light to the switch also.
I went with a true rocker switch to kill the power to the PC. I placed the switch behind the passenger seat.
Last Friday night my Screen died. PC booted as normal then screen did a gradient effect to black. The unit still powers but nothing comes up. the idiot lights still work so when I turn it on the blue light comes on followed by green, then finally the green light turns off followed by a amber light. The amber light stays on. I ordered the replacement control board hopefully that will fix my problem.
Software: OneVoice is pretty much a dead company afloat. The software is having problems with Win 7U in software registration. I called and email the company several times. Sad thing is I really like the software when it worked.
The Replacement Control Board for the Lilliput 629GL-70NP/C/T fix my problem with the LCD. Only if I could fix my One Voice.
08-06-10 Some how I got OneVoice up and running again. We see for How long...
Now that its fix, Media Center has mess its rows up. It add some new rows now I have something new to work on.
will update pics on next post.
