Page 16 of 18 FirstFirst ... 6789101112131415161718 LastLast
Results 151 to 160 of 179
Thread: 2003 Boxster S... I'm at it again!!!
  1. #151
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Very nice install! How is the Windows 7 MC going? I was having issues with it taking too long to initialize (after resuming from hibernation). I also didn't like it that it didn't resume to the same song, not even same playlist, not even last section (although I *think* there's a hack for that).
  2. #152
    Variable Bitrate Bigseven74's Avatar
    Jan 2008
    Quote Originally Posted by RipplingHurst View Post
    Thank you.
    I think there is no "one answer." All front-ends have there pros and cons some more then others. Based off these pros and cons we pick what works best for us, the end user. I did and do have some problems with WMC but there are more pros then cons. Resuming from hibernation works, no problems. The main problem for me is WMC scans for new albums on every hard boot. The more albums you have the longer it takes. When my PC comes out of hibernation there's about 2 secs of load. The resume the same song doesn't bother me. I use the "Play favorites" which it plays all of your favorite music.
  3. #153
    Jan 2008
    SSD installed
    I finally ordered a SSD off Newegg.com. I did a backup of the old 250 HHD (originally I used 148gb of at 250gb.100gb of that was music. so I have moved that to the 1tb HHD) it was only 48gb to move to the new SSD. I got a Intel X25-M 120gb SSD.
    new total...
    Pre built Carputer ---------------------- 467.13
    Double Din kit -------------------------- 169.86
    Double Din Lilliput 7" -------------------- 285.95
    Garmin PC w/ GPS ---------------------- 99.99
    Pioneer GM-3300T ---------------------- 78.37
    Microsoft LifeCam Show ---------------- 49.00
    One Voice version 3.1 ------------------ 52.18
    DashCommand ------------------------- 39.95
    mcShoutCast -------------------------- 10.00
    Jimmy's Car Stereo (labor) -------------- 50.00
    DB Link GB448 ------------------------- 11.00
    Horn relay ----------------------------- 6.92
    Glue Sticks ---------------------------- 3.97
    Velcro one wrap ----------------------- 4.67
    Velcro clear sticky back round tabs ----- 2.67
    corner brace x2 ----------------------- 3.96
    corner brace x4 ----------------------- 9.96
    plastic connector x2 -------------------1.96
    screws --------------------------------3.77
    screws--------------------------------3.77
    20ft patch CBL-------------------------15.99
    12ft patch CBL-------------------------12.99
    Pack of 2 Gold RCA Coupler x4-----------19.16
    10' Monitor Ext CBL----------------------32.99
    12' USB Ext CBL x4----------------------27.00
    120mm Fan x2---------------------------21.90
    Zonet USB 4 hub------------------------19.95
    External Slim 8x Drive--------------------76.99
    Snap Plug 22-16 GA x2-------------------4.38
    Snap Plug 16-14 GA x2-------------------4.38
    Snap Plug 16-14 M/F---------------------5.94
    25PK INSL. Splice x2---------------------6.28
    4GB USB Drive---------------------------27.99
    logitech Dual Action Controller -----------19.99
    Plexiglass-------------------------------45.25
    Corner Brace x2-------------------------13.92
    washers x3------------------------------2.94
    Screws----------------------------------6.24
    10/24 Screws----------------------------3.97
    12oz GLOSS Bumblebee Dec S-------------3.78
    12oz GLOSS Black Dec Spr----------------3.78
    Intel X25-M 120gb SATA II SSD-----------232.98
    Total------------------------------------1976.86
  4. #154
    Aug 2011
    Tauranga N.Z
    I am interested to know how to re size the touch icons at the bottom right as they are to small
  5. #155
    Jan 2008
    maybe this is what your looking for?
    http://www.sevenforums.com/tutorials...idth-size.html
  6. #156
    Aug 2011
    Tauranga N.Z
    This changes the size in the task bar.
    What I am trying to do is change the size of 13 function buttons bottom right on WMC or even remove some that I do not need such as rec and others
  7. #157
    Jan 2008
    Change #3
    Chasing Perfection
    Relocating the PC, New Multi touch Monitor, New head unit , new back up camera (the old one was about to catch a fire, it was a bad unit), and bluetooth OBII. Replaced one Tang Band Subwoofer.
Size:  236.7 KBName:  DSC01767.jpg
  8. #158
    Jan 2008
    PC new location
    I moved the pc under passenger seat. I had to remove the Driver seat to run the back up camera VGA cable to the head unit.
Size:  208.4 KBName:  DSC01770.jpg
  9. #159
    Jan 2008
    Running the Backup VGA cable and backup wire
    So much for two wires, but you have to pay the cost...
Size:  173.4 KBName:  DSC01772.jpg
  10. #160
    Jan 2008
Size:  366.3 KBName:  DSC01774.jpg
  1. Copilot 2003 Activation
    By bridqer in forum GPS
    Last Post: 08-15-2004, 12:21 PM
  2. CoPilot 2003
    By faz211 in forum GPS
    Last Post: 08-11-2004, 09:45 AM
  3. Replies: 5
    Last Post: 05-12-2004, 09:42 AM
  4. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 09:11 AM
