Center console was hacked like the 2001 Boxster S I did. Usb hubs are inside the center console.
(Sorry for blurry pics)
I used a car kit so I could I tap into the system wires. Then I started to have problems. The car kit (wire kit) was wired wrong. I couldn’t find the true accessory and constant power. I end up taking the car of to one of my local car shops. After three visits the problem was solved. It turned out that the car didn’t have a true accessory pin so it was wired into the ignition.
I finally tapped into the old speaker wires. Everything is on quick release connectors.
Things were cleaned up at this point. I decided to keep the stock Bose amp in the car. The amp will not be use with my setup.
Finished with the trunk.
The speakers upgrade Bose to Boston Acoustic.
The door speaker box had to be bored out but I still left the stock screw holes. Problems with getting the door panel off, but after 30 mins I finally got it off.
I actually thought that this was going to be the hardest thing to do. It turned out that the screen was the easiest of all things.
I started putting the pc stuff into the car. This is my webcam it’s next to the keyhole.
The screen is a LILLIPUT 7" 629GL-70NP/C/T VGA TOUCHSCREEN. These pics were taken with the top down. It was sunny on the day of the pic, but it not taken in direct sunlight.
