Page 9 of 18 FirstFirst 123456789101112131415161718 LastLast
Results 81 to 90 of 179
Thread: 2003 Boxster S... I'm at it again!!!
  1. #81
    Variable Bitrate Bigseven74's Avatar
    Jan 2008
    How I Customized Windows Media Center to my liking with Media Center Studio
    Open “Media Center Studio”
    Look are a tab called “Start Menu”
    Click on it.
    Here you can edit the look of rows.
    *make small changes, and save as you go.
    *at this point you are making multi backups to the folder “ehome” there were several time when I had made a save and something I did crashed the program. Doing this, all I had to do was delete the bad folder. Drag and drop a good folder rename it to “ehome” and I was ok again.
    *in the upper left hand corner there is a save and a quick lunch for WMC.
    When you move the mouse over the “Name of the Row” there will be two icons on either side of it.
    The check box is used to turn on or off the row.
    The notepad is used to rename the row.
    You can also grab and movie any box anywhere. (i.e. move music library to the Tasks row)
    At the bottom of the left hand corner there is “Entry Points”. This is you selection of apps internal and external. You may drag and drop them as you like.
    To add a “new row” or “application” click on the “Start Menu” tab.
    To add a” new row” click on “Menu Strip.” It will be at the bottom of the page. The name of it will read “Custom menu”
    To add a new external application click on “Application” under the “Start Menu” tab.
    Here you can specify what happens to the audio and more.
    Save and test.
  2. #82
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    VERY cool. Thanks for that! Bookmarked, I'll try that some day. I have no graphic talent though, so let's see what happens.
    Thanks again.
  3. #83
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Thanks for this 'How to'
  4. #84
    Jan 2008
    sure thing. let me know know if you need anything else.
  5. #85
    Apr 2009
    Quote Originally Posted by Bigseven74 View Post
    Open Restorator 2007. Drag and drop “ehres.dll” into the Resource Tree.
    Click to expand the folders. Click on RCData. All the pictures are saved as “.png”
    Here is where you can change the look of WMC. But if you still haven’t back up the “ehres.dll” file you will to. If you miss up the file there’s no turning back.
    The main Files I focused on to edit were:
    *Here is where I used Photoshop to crop, clean up, and fix an image that I was to use.
    Pay attention to the size of image you will replace. Crop your image down to the same size. (I read that common.animated.background.png” can be replaced with a much larger image. Seeing that I was using this in my car the default size worked for me.)
    Once you have your replacement pictures ready. Go to the image that will be replaced.
    Right click on it.
    Click on “Assign”
    Click on “Assign to”
    Select the picture you will replace it with.
    The new picture will be assigned in its place.
    Repeat till done with pictures.
    hi,
    me also making mine wmc but could not save ehres.dll file in restorator.
    i have logged in as administrator, but it did not save so i chose to save on next system start(restorator option), but it did not make it. i have tried to do by renaming did not allow again. then i looked the permissions and see that i do not have permission to write so i tried to change it but it did not even allow me to edit the permissions.
    i am using win7, did you make it with xp?
    i have solved it by chaging the ownership of the file
  6. #86
    Jan 2008
    ***the forgotten step***
    I'm running win 7u 64bit in the car. I made the changes with my win 7u 64bit HP laptop. I think I ran into the same problem as you did. Win 7 is particular about the curtain folders. Sorry I missed that step.
    THIS STEP GOES AFTER ''How I Customized Windows Media Center to my liking"
    After you back up the folder and the file "ehres.dll" drag the file (ehres.dll) to the desktop. From here you can take ownership of the file.
    drag this file into Restorator. Edit the file to your liking then save it to the desktop again.
    Once done with the file drop it back into the ehome folder (”C:\Windows\ehome”)
  7. #87
    Jan 2008
    Bluetooth Add-ons
    I added some new software to the car. This piece of software is from BlueSoleil. I bought their BlueSoleil 6 and cPhoneTool plug-in. With this Bluetooth software I can pair up my Touch Pro with the pc for hands free calling. I can dial on screen and update contracts list all through cPhoneTool. If I'm listen to music I can call cPhoneTool up via One Voice. So far the only two things I don't like about the software are, the price and inability to maximize it to full screen.
  8. #88
    Jan 2008
    BlueSoleil cPhoneTool
    Not sure what the window size is my guess is 800 x 600
  9. #89
    Jan 2008
    future plans
    Change the OS HDD to SSD.
    Thats it.
  10. #90
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Thats it.
    LOL, short and simple..... Love it.
    HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
    4x 10inch Tablet
    1x Win 7 / Rear Entertainment PC
    ft/ Web Server Streaming
  1. Copilot 2003 Activation
    By bridqer in forum GPS
    Last Post: 08-15-2004, 12:21 PM
  2. CoPilot 2003
    By faz211 in forum GPS
    Last Post: 08-11-2004, 09:45 AM
  3. Replies: 5
    Last Post: 05-12-2004, 09:42 AM
  4. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 09:11 AM
