Results 1 to 10 of 10
Thread: 2005 Nissan Frontier Crew Cab 4x4 Nismo
    Feb 2008
    Second installation in my second vehicle (See my other installation
    Parts List:
    Hardware:
    -Acer Asipire One 8.9" 1.6ghz Netbook with the GMA950 Graphics Controller, Wifi, bluetooth, etc.. all the interfaces needed, enough horsepower to do the job.
    -Lilliput 840x480 LCD with LED backlighting @ 450nit Brightness (resistive touch screen, not capacitive[yet])
    -Bybyte.com double din EBY701/629 framing mount
    -SIRFF III USB GPS Antenna
    -Bluetooth OBD2 interface
    -Arduino USB programmable board for controlling RGB ambient interior lights, turning on and off component's relays in/outside the truck, tap into temperature sensors, also could be used to be programmed to run the HVAC system... will take a while.
    -Plastic wire flume and wire fittings.
    -Some thin stainless steel to mount the computer inside the dash.
    -Mini-box.com USB Programmable DC-DC Power supply.
    -12v 17mAh Lead Acid Backup battery
    -12V 40 AMP solid state relay (to isolate the computer system's power from the truck's main power, computer will only rely on the small 12v Lead acid battery with key in OFF position)
    -USB Steering wheel control board to use my factory steering wheel controls.
    -Wire hardness to tap into the factory Rockford Fosgate amplifier's low level RCA inputs for full range audio, less cutting of wires, no messing with factory audio wire harnesses.
    -600w RMS Sony amp for subwoofers
    -Under rear-Seat dual 10" carpeted subwoofer box
    -Two Sony Xplod 350RMS 10" subwoofers
    Software:
    -Garmin Mobile PC GPS Software
    -License for Centrafuse 3.0 Front end media system software
    These are all cellphone snapshots of the progress of the installation so far(i'll have more soon, maybe some demonstration videos too):
    The Truck:
    Soldering wires to the power button of the laptop's motherboard
    Installing the LCD into the double din mount bracket
    Getting all software installed and configured
    Taking the dash apart, hooking up the audio harness and RCA cables, zip tying wires, trying to make things look neat the best I can, installed computer behind the clime control unit in the lower dash:
    Getting the LCD installed and lined up with the dash stereo bezel, if you look real hard, you'll see where the computer is installed down lower inside the dash
    Closer Look
    Looking alright so far...
    Glare isn't terrible for a mid-daylight shot
    CB radio installation, got a 80watt 5" loudspeaker installed too for PA, ooo yeah.
    The rodeo, and the frontier:
    More soon, still waiting on my USB GPS antenna and USB Programmable power supply.
    Feb 2008
    No comments eh ?
    fine.
    Newbie RedScorpion's Avatar
    Sep 2008
    Loma Linda California
    Thumbs up
    Looks immaculate, good job!
    Jun 2009
    London, United Kingdom
    Nice work... jesus I wish my car came with a double din space, it makes life so much easier!
    Did you make the laptop removable?
    Aug 2000
    Quote Originally Posted by TheGuv View Post
    lol, just cut a whole whatever size you want in the dash
    Jun 2009
    Not quite as easy as that lol!
    Low Bitrate Xygar's Avatar
    Jul 2009
    Provo, Ut
    I like it. Looks really clean. Is the Acer powerful enough for you? I've got an eepc (not in my car ) and it doesn't do video well.
    May 2010
    Looks nice and clean. Is that Anti-Flag on the first shot of the LCD playing Confused Youth?
    Feb 2008
    That is anti-flag haha!
    The 1.6ghz and gig of ram does perfect.... does really good, i havent run into any problems at all with speed, CF3 is a POS compares to CF2 when it comes to performance in ANY machine, but, all is very functional, video is perfect, winamp visualizers work well with the GMA950, etc..
    Nah, didn't make the laptop removable. Might put my extra Eee Box with the exact same hardware in it instead sometime, an extra netbook lying around would be nice to have.
    Been a great installation though, really happy with it, Solid.
    I highly recommend the programmable USB power supply from mini-box.com and the JoyCon steering wheel controls interface.
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Your build gives me a lot of ideas if I ever re-do the build in my Xterra. Nice to know that the newer bybyte frames fit the dash opening properly now.
  1. 2005 Nissan Frontier (PC, Flip Down Install) "The Darkness"
    By patsfanwilly in forum Show off your project
    Last Post: 03-29-2010, 04:07 PM
  2. Replies: 1
    Last Post: 08-10-2009, 10:28 PM
  3. jjnit's 2005 Nissan Frontier LE Crew Cab
    By jjnit in forum Show off your project
    Last Post: 04-01-2007, 12:43 PM
  4. another n00b - 2004 nissan frontier install
    By chaotic in forum Newbie
    Last Post: 03-18-2007, 06:37 PM
  5. Where to DL old version of RR?
    By accentsound in forum Road Runner
    Last Post: 07-12-2005, 12:51 AM
