Results 1 to 3 of 3
Thread: 2004 Mitsubishi Lancer - Ralliart
    Mar 2007
    Maryland, for atleast 3 months, then VA?
    I have had a car computer for several years, but never got around to posting any images. I figured now was as good as anytime. More pictures/description on the way.
    Concise project scope:
    - Hardwired Inverter
    - Car PC
    Mini ITX
    VIA MII-12000 Platform
    MII-ATX power supply
    XP SP2 Operating System
    Road Runner Frontend
    IGuidance NAV
    Evoscan for ECU logger
    - Backup Camera
    - Custom designed interior floor lighting
    Project Start Date - Spring 2005, Completion - Spring 2006
    2004 Mitsubishi Ralliart Lancer
    Lilliput 619 7" Touchscreen
    EPIA MII-12000
    512 MB RAM
    160 GB 2.5" Drive
    Black VoomPC Case
    Mar 2007
    Hardwired Inverter
    I replaced the back seat ash tray with a 110V GFCI outlet and a metal outlet cover made it blend in with the rest of the car.
    -Forgive the black sheet and towels in the back seat. I case you didn't notice the enormis amount of hair in the car, suffice it to say, I have a dog. The fitted black sheet and towels is the best option I have found to keep the upholstery nice while being able to transport the dog.-
    Setup works great for long road trips with laptops/cell phone chargers. Less of an issue with longer battery life in current laptops. Was awesome in 2005.
    EPIA MII-12000
    512 MB RAM
    160 GB 2.5" Drive
    Black VoomPC Case
    Mar 2007
    PC System Design / Schematics
    Here is the general design of the system. Knowing what I know now, I would definitely build it differently. However, considering I designed this when I was a freshman engineering student and built it as a sophomore, the system has worked great.
    There have been two hardware failures in 4 years. The <AudioOut> on the motherboard failed (replaced a protection diode to repair), most likely due to circulating ground currents. The inline FM modulator failed in the same time frame (failed transistor, replaced), most likely due to circulating currents. Failures happened after 2 years. I corrected the issue by adding an isolation circuit, and have had no other problems. Tank circuit has started to get a little weak. Good for about 30-60 seconds instead of the original 10 minutes depending on temperature. Considering it easy experienced +2500 startups, and a lead acid battery just isn't made for that, I'm satisfied with the performance.
    Below are slides from a class presentation on this project.
    POWER CONDITIONING OF INPUT
    COMPUTER SYSTEM
    *Note, hard drive is installed outside computer case. Resides in a foam holder, vertically mounted for shock. MII-12000 motherboard in final build. MII-ATX in final build.
    AUDIO INTERFACE TO STOCK SYSTEM
    EPIA MII-12000
    512 MB RAM
    160 GB 2.5" Drive
    Black VoomPC Case
  1. 2004 Mitsubishi Lancer Ralliart
    By dvwjettaiii in forum Worklogs
    Last Post: 01-31-2011, 01:41 PM
  2. 2004 Mitsubishi Lancer LE Car pc Installed Bangalore India
    By mpsreejesh in forum Show off your project
    Last Post: 04-12-2009, 09:06 PM
  3. 2004 Mitsubishi Magna VR Car PC
    By MitchellO in forum Worklogs
    Last Post: 12-31-2008, 11:12 PM
  4. Replies: 3
    Last Post: 08-26-2006, 10:54 PM
  5. Replies: 2
    Last Post: 08-10-2006, 10:43 AM
