Results 11 to 20 of 21
Thread: 1994 Peugeot 106 XS beeing upgraded just a bit
  1. #11
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    Just posting a few idea's for the software part,
    going to tweak my xp install as per this guide: http://www.tweakhound.com/xp/xptweaks/supertweaks1.htm
    decided to try to skip nlite first and see if i can fit my install under 16 gb so that i can run it off a usb stick
    also going to make a horm+ewf system as per this post: http://www.mp3car.com/vbulletin/road...ml#post1299862
    more detail on that post here: http://blog.granturing.com/2007/12/t...ginal-ewf.html
    the 5 meters extension for my screen is on the way and should be here tomorrow, the microphone is only with a meter cable so i think i will leave a wire under the roof that i can use to pull the remaing wires... have not made up my mind on that yet...
    so back to checking ID3 tags on my music
    one thing is that id3 tags are ok, need to get good art also... might use this tool to do that for all albums at once: http://www.unrealvoodoo.org/hiteck/projects/albumart/
    might also change my resume from hybernation screen as this is the only one i'm going to see if i get horm to run perfect
    http://www.mp3car.com/vbulletin/gene...tml#post306672
    Blessed are the "cracked" for it is they who let in the light.
  2. #12
    Oct 2008
    Odense, Denmark
    first post updated.. software install started
  3. #13
    Oct 2008
    Odense, Denmark
    a small update, rear of the car coming back together. All software installed (garmin missing).
    rest of rear should be done tomorrow.
  4. #14
    Oct 2008
    Odense, Denmark
  5. #15
    Oct 2008
    Odense, Denmark
    another small update.... made myself a power up/down controller.
    also got myself a 13 port powered usb hub, maybe overkill?
    next step is to run power wires in the install box... but if I do that today is up to my lazy butt
  6. #16
    Oct 2008
    Odense, Denmark
    minor update... install box almost fitted and installed
  7. #17
    Oct 2008
    Odense, Denmark
    pic of almost done install box added.. need to run power to and from the power controller
  8. #18
    Oct 2008
    Odense, Denmark
    first post upated... i'm getting there
  9. #19
    Oct 2008
    Odense, Denmark
    first post updated, a small setback as onboard sound is not up to the job
  10. #20
    Newbie Angel106's Avatar
    Oct 2009
    Hello my name is Angelo and I am writing on Italian site.
    Also I'm doing my project on a Peugeot 106.
    Here is the link of my project where I put photos: http://www.carputer.it/showthread.ph...t-106-106CarPc .
    I'm curious to see more photos of your project.
    Hello to you soon.
  1. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-16-2012, 01:35 PM
  2. AUDI CONCERT 3, MP3 OEM RADIO HACK. Help!!
    By coucouillu in forum Hardware Development
    Last Post: 01-16-2011, 04:53 PM
  3. VAG-com cable on peugeot 106
    By KoBolD in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-23-2006, 02:51 PM
  4. OBD-II on a peugeot 106 GTi
    By ldjones48 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-10-2005, 09:50 AM
