what brand is the rackmount audio gear and what did you go through to convert them?
ZX1 Cruizer, did you wrap your center console or did you have somebody do it? I noticed it's even stiched, that seems like some hard work now that I'm looking at it.
Wow that looks so cool. Its nice how it all fits into that slim form factor. Let me ask, are the air vents at the front, which would be your top? If you cover it with plexi, wont that block those holes? Well it depends if you can sow. Also make sure to use padding under the vinyl or it will bubble.
I did not wrap my console. i designed it, told a upholsterer what I wanted and he did his magic. i was very impressed with the guy I used because in the past, the upholsterers would use glue to hold it together. Over time heat would make it come undone. Then I found this guy and he does this stitching which makes it look OEM. He does upholstery on luxury yachts so thankfully he translates his luxury work into all his projects. Hes going to be ****ed that he may have to redo my rear hatch because I want to redesign it to be different.
HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
4x 10inch Tablet
1x Win 7 / Rear Entertainment PC
ft/ Web Server Streaming
I'm running a Behringer DEQ2496 (http://www.behringer.com/EN/Products...x/DEQ2496.aspx) and two Behringer DCX2496 (http://www.behringer.com/EN/Products/DCX2496.aspx)
I've used several different Active crossovers and 31 Band EQs, but this is my current setup and I really like it. In the past i've used Image Dynamics graphic EQ and active crossover, Kicker crossovers, and once had a Pioneer Premier P-9 Combo. The great thing about the DEQ is that it accepts the digital optical toslink from my mobo, and has a mic input with RTA and auto tuning. All have clipping and limit LEDs too. There's so much these units will do, and even though they aren't top of the line prosound gear they work nicely in the car. To convert them to 12V, i just bought these power supplies (http://envisionelec.net/index.php?ma...&products_id=2) They work great, easy to install, and soft on/off. You can also connect the DCX to your carputer and adjust all the settings that way, but since my units are in the console to my side I just adjust it by hand.
Also, the prosound gear outputs are XLR, so I bought a spool of microphone cable and soldered XLR and RCA ends. You can buy adapters too.
I'm sure he'll like the business though!
The normal airflow for the 1U is at the front yes. I run the PC with the top of the case off at the moment. I do have a 1U space vent above the computer and below the DEQ. This is sort of for looks and to take up space, and it also functions as a vent to allow heat to escape. I would consider venting out the side or back with fans if I did cover with plexiglass. I wouldn't think that would be much of a problem. I doubt i would be able to sew but I love how it adds that much more custom/factory look to it. I'm still unsure on how I will wrap this monster. I'm already thinking about moving the 10.4" screen into the dash and moving my AC vents to the center console. I have a head unit in my dash, but it's not even hooked up to anything. Just there to take up space and fill the hole, becuase I go from my motherboard's digital out to the prosound gear.
This is one mean setup. Do you compete in SQ competitions?
I don't compete in anything. I've never been to a proper competition either. This is a hobby I picked up when I was in the USAF stationed in the UK to keep me busy and everything I learned has been from reading and trial and error. I'm really into SQ and would like to start going to shows to check peoples stuff out and listen to others rides though. Even if I do go, it would be for feedback more or less to improve my sound setup. I do it for more of the personal satisfaction/enjoyment :-)
Wow. How much power does that all consume? Did you install a new alternator to power all that too?
WOW!!! With $400 is power supplies alone, I would try an inverter first and see what the result was. Speaking of...did you try an inverter at all? The only reason I ask is because I am thinking of doing a setup similar to yours in my Dodge 3500 and I already have a 1800W inverter in the truck for other gear. It would be MUCH easier for me to just run things off 120VAC if there aren't any problems. OOPS...I suppose I should mention that my AutoPC will be running off the inverter as well, that is, whenever I decide what stuff to put in the truck.
I don't know specific number, but I am running two batteries seperated by a 200 amp isolator and upgrade my alternator, so I don't really have any power issues. I have loaded lots of pictures in the worklog subfolder. I made a rookie mistake in posting here first. You should check it out if you get the chance.
It was pricey... over time. I started off with some similar rackmount Image Dynamics stuff that was 12V, sold it, bought a pioner P-9 setup, then sold that to try the Behringer stuff. I discovered the modification people were doing on car audio forums and liked what those units had to offer. I started with just one DEQ for the 31 band eq and RTA self adjustment, then added a DCX, and then another DCX when my setup went from 3-way to 4-way (Low, Mid Bass, Midrange, High). As I added I just kept buying the units and the power supplies. Thats the main reason I did the rackmount computer chassis becuase I figured it'd look really cool all together in the middle of my truck if I took the middle seat/console out.
I never did try using an Inverter on the prosound gear. If I did, i'd definitely buy a powerful pure sine wave and use that for sure. I did use a cheap inverter on my pc between blown OPUS and my M4 power supplies and it seemed to work fine, although I could hear slight noise, but very inaudible with music playing. If I had to do it again, I'd probably try that first. One thing I didnt like about the inverter is the standby current it drained my battery if my truck sat for two days or more and then would give an annoying high pitch beep. I remember the first time I heard it i was like WTF when I walked by my truck and then discovered what it was lol.. anyway yeah if you do a similar setup you'll have to let me know how it all works.
BTW, i supposed the advantage of 12VDC setup is everything is running off the standard 12v constant, 12 turn-on, and ground wires so they are controlled like everything else. I'm not sure how the prosound gear would work if you connected to a inverter, perhaps some sort of relay controlled by the ignition that cut power between the gear and inverter? Or turned off the inverter entirely, but then the computer would need to be in hibernation or off, so one wouldn't have quick boots from standby/sleep. Let me know i'm curious about this. Right now my turn key to music is near instant with windows 7 in standby.
