Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: 2002 Toyota 4runner CarPC
  1. #11
    Low Bitrate Lankin's Avatar
    Jun 2009
    In reference to problem number 2:
    Make sure you use the actual ignition power as the acc for your m2-atx. If you used say the acc wire that goes to your head unit as the acc for the m2-atx then this would cause your problem. This is because when you turn the key on your car the electrical system temporarily cuts power to peripherals such as the head unit in order to ensure that it is not damaged during the high amps.
    key in acc mode: acc line gains power: computer turns on
    turn key to crank engine: acc line loses power: computer turns off
    engine started: acc line regains power: computer turns on
  2. #12
    Aug 2005
    MD
    Quote Originally Posted by Lankin View Post
    But if you connect IGN power to the ACC line then how will the computer turn off/standby/hibernate?
  3. #13
    Jun 2009
    oh sorry I didn't realize how confusing that post might have came off as. When I was referring to the ACC on the m2-atx i was actually talking about the J3 power input connector.
    manual:
    http://resources.mini-box.com/online...anual-engl.pdf
  4. #14
    Newbie Exstatica's Avatar
    Apr 2010
    UPDATE: Pictures, mostly completed. Probably can be pushed to show off my projects
    Answers to others:
    There is a dedicated feed that powers the amps, carpc, usb hubs, hd radio, and the monitor. So power should never just be cut off.
    It only happens when I turn the car off. Probably just the crappy M2
  5. #15
    Apr 2010
    Another SSD Failure, this is 3rd one with 2 different brands. I don't think its the SSD, I think its the power supply is not providing enough power or something.
    I guess I'll order something bigger and more reliable, anyone have a suggestion?
  1. any one have 1998 toyota 4runner wireing diagram
    By dishpro1125 in forum General Hardware Discussion
    Last Post: 06-27-2011, 08:53 AM
  2. 2002 Toyota Highlander Build
    By joelikefire in forum Newbie - Proposed setup
    Last Post: 06-01-2010, 03:29 PM
  3. 98 toyota 4runner wiring diagram
    By No_Bass in forum Car Audio
    Last Post: 04-03-2010, 11:40 AM
  4. Toyota Wish CarPC Install
    By Cycfari in forum Show off your project
    Last Post: 12-26-2009, 06:37 PM
  5. Replies: 17
    Last Post: 07-27-2007, 05:05 AM
