Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
Thread: 2002 Volvo S60 Super Connected Car PC
  1. #21
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by PaulF View Post
    If you want, I'll make a small php file with functions like relay(relayID,state) or getAnalog(sensorID) so you can directly interface with the brain.
    the code on your part would then be as simple as:
    PHP Code:
    <?php
    include 'fusionFunctions.php'//gives access to fusion brain daemon
    relay(5,1); //turns on relay 5
    relay(7,0); //turns off relay 7
    print getAnalog(2); //prints the analog value of sensor 2
    So, for example, I could code a web page with buttons on it like 'Relay 5 - ON' and point it to a script that was, say, "relay7_on.php" and it would turn it on?
    Want to:
  2. #22
    Jan 2008
    Dartmouth, MA
    Quote Originally Posted by Bugbyte View Post
    I'll PM you so we don't hijack the thread. I'll show you a few neat php tricks that make this easier than you imagine.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  3. #23
    Jan 2008
    Dartmouth, MA
    Quote Originally Posted by HiJackZX1 View Post
    I agree.... Web design and building computers I learned by just doing them. God know ive had to learn a lot with this hobby. I am trying things I would have only imagined.
    There you go. You've got web design, now expand into javascript. From there take on something that looks like javascript... like C# (Best Programming Language Ever, yes I'm biased) or Java (Piece of crap).
    Well at least you did that.... I have to out source any fabrication.
    It's not to difficult if you go about it how I did. If you can work with wood, you can spread bondo over it and sand to get that plastic-looking finish. There's another thing to throw on your "try" list. haha
  4. #24
    Jan 2008
    Dartmouth, MA
    I've began to program a stand-alone cross platform application which allows you to control the Fusion Brain across the internet and from a variety of programming languages. Check out this forum post: http://www.mp3car.com/fusion-brain/1...-internet.html
  5. #25
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Cant wait to see..... youve been very quiet! What was the name of the 12V - 5V stepdown that you use? Would this one be any good? http://www.current-logic.com/shop/in...roducts_id=190 What I like about it is that it has a total of 70amps. That could power just about everything and then some.
    HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
    4x 10inch Tablet
    1x Win 7 / Rear Entertainment PC
    ft/ Web Server Streaming
  6. #26
    Jan 2008
    Dartmouth, MA
    The Mean Well brand converters have been working well for me for over a year. I'm using their 50 watt, 5 volt supply. http://www.jameco.com/webapp/wcs/sto...0001_212549_-1
    50 watts is definitely overkill in my project. But those current logic supplies look pretty nice with efficiencies over 95%, high current, and high temperature tolerance. I've never used them so I can't speak on reliability, but if that's the current you're going for, those look pretty good.
  7. #27
    Jul 2007
    Miami
    Let me ask, the devices I connect will only use what they need? They wont overload anything will they. I estimate I will only use about 30 amps. Just want the extra for future proofing.
    Also for you car, you have a dedicated connection? What are you using for it? Company, etc.
    4x 10inch Tablet
  8. #28
    Jan 2008
    Dartmouth, MA
    Well the devices power consumption will definitely fluctuate a bit. What devices are you powering that are going to eat 30 amps at 5 volts?
  9. #29
    Jul 2007
    Miami
    Well its a number of them:
    1 7 port USB Hub (1 amp)
    1 Ethernet Switch (2 amps)
    6 KVMP Switches (2.6 amps each)
    So its only about 20 amps. With that being said I decided to lower it to a 12V - 5V 30 amp unit. So thats 10 amps to spare.
    Let me ask, I am going by the amperage listed on the devices. Is that the max that they can use? Then technically I dont need more then 20 amps?
    4x 10inch Tablet
  10. #30
    Jan 2008
    Dartmouth, MA
    The USB hub consumption sounds about right assuming you're using every port.
    I *HIGHLY* doubt those KVMP switches use 2.6 amps each. Are you basing that number off what it says on the power supply, or does the device state what it requires?
    I would double check that with a multimeter. I would be surprised if they even consumed 1 amp. They do next to nothing except power some multiplexing circuit and some LEDs. I bet the LEDs use more power than the rest of the KVMP combined.
    But, definitely, do double check before taking my assumption for fact.
  1. install mac mini
    By ssteger in forum VaultWiki
    Last Post: 02-09-2010, 02:47 PM
  2. Replies: 22
    Last Post: 12-17-2009, 06:21 PM
