Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 42
Thread: 2002 Volvo S60 Super Connected Car PC
  1. #31
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by PaulF View Post
    The USB hub consumption sounds about right assuming you're using every port.
    I *HIGHLY* doubt those KVMP switches use 2.6 amps each. Are you basing that number off what it says on the power supply, or does the device state what it requires?
    I would double check that with a multimeter. I would be surprised if they even consumed 1 amp. They do next to nothing except power some multiplexing circuit and some LEDs. I bet the LEDs use more power than the rest of the KVMP combined.
    But, definitely, do double check before taking my assumption for fact.
    For the KVMPs, I am going by whats on the adapter because the device does not list it. I assumed it was accurate because the KVMP has a KVM (the multiplexing circuit your talking about) with an added USB Hub with it. Its how I allow two computers to share one touchscreen, its the only KVM that seems to do this. I tried to have the PC power it, but when I turned on the PC, it didn't play nice at all. Connected to the KVMPs are Mini-Pac controllers (emulates the keystrokes to switch the KVMP from PC to PC), then touch screens. I think the touch screens get their power from the screen itself, but I'm not sure because I remember that when I had shut the screen off one time, I could still hear the touchscreen beep when I pushed it. So that would mean its powered by the USB port?
    Also you didn't answer (or I didn't see it) what you use to keep your car connected to the internet. Basically I would love my car to be always connected, but paying $60.00 a month is a stretch for me, especially since my car is more multi-media based then connected car based. I see that millenicom has a $39.99 WiMax plan, but WiMax is so limited in my area right now, and it does not have 3G fall back.
    HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
    4x 10inch Tablet
    1x Win 7 / Rear Entertainment PC
    ft/ Web Server Streaming
  2. #32
    Jan 2008
    Dartmouth, MA
    Quote Originally Posted by HiJackZX1 View Post
    A USB hub in and of itself uses (on average) a maximum of 100mA. Of course, you need to factor in the load.
    I doubt a touch screen draws much at all from the USB port, but it would make sense to power the overlay over USB so they don't have to spend money on an internal 5 volt regulator and deal with the added heat/circuity complcations.
    Sorry about that, I keep needing to repost due to the forum being someone broken. Yes, I'm paying 60 bucks for the verizon 3g plan right now. But that's going to change when the contract is up.
    Right now:
    I have the sheeva plug running PPPD in a persistent mode top maintain the 3g connection and a script that pings google.com every 2 minutes to keep verizon from dropping the connection.
    I have the wonderful linux iptables doing some work as a gateway from the ethernet port to the 3g modem. Works perfectly, 100% reliable.
    To save money I plan to get rid of the 3g plan and add an android phone to my mother's family plan and since she's a teacher in MA she gets a 15% discount. $9.99 to add a phone, $30.000 for data... $40 x .85 = $35/month. I'll likely root the phone and do some networking magic to turn it into a decent internet connection with enough IPs to go around. I may even just attach it to the SheevaPlug and have the plug dial it as a modem...
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  3. #33
    Jul 2007
    Miami
    I cant wait to see what you come up with. People think I'm crazy for focusing so much on Multi-Zone, but I think your equally crazy for focusing so much on constant connectivity.
    4x 10inch Tablet
  4. #34
    FLAC hexxamillion's Avatar
    Dec 2007
    AZ
    Awesome! Simply awesome!
    "Live Free!!!...It's all about Open Source"
    Current Proj:'09 Altima In-Dash Android Tablet and System Upgrade
    Old Proj II
    Old Proj I
    YouTube:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
  5. #35
    Dec 2007
    AZ
    I am looking into one of those yellow top Optima batteries. So I see you have yours mounted in your trunk. Have you had to recharge yet? or how do you manage the power for your always on accessories?
    I'm just trying to understand things that I need to consider. I'm using a tablet as my carpc solution and while I have not had to worry about charging but I may consider integrating some always on solutions. For example, I have a bluetooth device connected in my car but powers on/off with the car. There is a delay for it to be connectible with my tablet after it powers on. I want to have it always on so that I will have instant connectivity with my tablet. Suggestions?
    Old Proj II
    Old Proj I
  6. #36
    Dec 2007
    AZ
    I think I answered my own question and will probably look into getting a smart charger designed to work with the AGM batteries.
    Old Proj II
    Old Proj I
  7. #37
    Jan 2008
    Dartmouth, MA
    Hey hexxamillion,
    I hadn't been to the forum in a while so I wasn't getting email notifications! Funny thing too is that I'm about to make a post in my new work log about power in my new install.
    Anyway for charging, I actually had a fairly complicated system in place for this install.
    The always-on accessories were attached to a tiny alarm-system battery to mitigate voltage fluctuation/power source switching.
    The power to that battery came through a diode. On the other side of the diode was a relay that switched between getting power from my blue-top Optima and a 13 volt power supply.
    The blue top optima was charged by a 25 amp charger.
    So when you plugged in the car, the relay would make the electronics run off the 13 volt psu, and would charge the optima battery.
    Otherwise "smart chargers" would overcharge the optima falsely thinking it was always undercharged and this also improved charge time.
  8. #38
    Dec 2007
    AZ
    Great insight. Thanks! Lets me know what I need.
    ««« Sent from my ultimate Galaxy Tab using tapatalk ...and I'm probably in my car : ) »»»
    Old Proj II
    Old Proj I
  9. #39
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    PaulF, do you have current readings for individual components of your setup? Is this your "new" worklog?
    Former author of LinuxICE, nghost.
    Current author of nobdy.
  10. #40
    Jan 2008
    Dartmouth, MA
    Quote Originally Posted by tripzero View Post
    This is my most recent worklog. I'm pretty bad at keeping worklogs up to date though. What the end result of this project was:
    -FitPC2
    --Only computer
    --Around 8 watts
    --windows 7
    --centrafuse
    --120gb SSD
    --standalone C# & IronPython application for controlling the fusion brain V4
    --USB 3G modem
    --Web server in the C# app
    --around 8 watts
    -A pretty standard lilliput HDMI touch screen
    -30 watt solar panel mounted on roof
    This was a complete failure for an always-on system without charging. I'm in Boston now, so I can't just plug my car in -- hence the solar panel. So during the summer I would park on the roof of my parking garage. Battery would be flat dead in 3 days.
    I'm about to make a new worklog for my latest and greatest system which is microcontroller based with GSM/GPRS connectivity. I'm staring at a multimeter that says 44.6mA right now @~12volts - and that's without any power optimization.
  1. install mac mini
    By ssteger in forum VaultWiki
    Last Post: 02-09-2010, 02:47 PM
  2. Replies: 22
    Last Post: 12-17-2009, 06:21 PM
