Results 1 to 9 of 9
Thread: 2001 Grand Cherokee CarPC install - 10" monitor
    Aug 2010
    Talking 2001 Grand Cherokee CarPC install - 10" monitor
    1 x Lilliput 10" HDMI touch screen monitor
    1 x Jetway JNC63-330-LF 1.6GHz Dual Core ATOM + nVidia ION Mainboard
    1 x Kingston 2GB 800Mhz DDR2 DIMM
    1 x M2-ATX-HV 6V-32V 140W Intelligent Car PSU
    2 x 4 Pin to 4 Pin 12V AUX Power Cable
    1 x CarPC Chassis
    1 x Globalsat BU353 USB GPS Receiver - SiRF Star III
    1 x Dynamode USB Micro Bluetooth Adapter - 100m Range
    1 x Seagate Momentus 5400.6 160GB SATA 8MB Cache - ST9160314AS
    1 x WINTV Ministick USB HD ( ver 7 wintv )
    1 x 30GB Kingston Solid State HDD (for the OS)
    1 x Destinations Navigator 10 PC GPS Software
    5 metres of every cable.
    Jan 2009
    mp3cherokee,
    Thanks for checking out my project and for your comments. You certainly did a good job. In particular installing a 10-inch monitor, and making look OEM. Finding room for a 7-inch monitor is a challenge, let alone for a 10-inch. One thing that you need to be cautious is using a normal hard drive. They tend to go back quickly over time because they are not designed to withstand driving conditions such as temperature extremes and vibrations.
    Thanks,
    dominicanjb
    Sep 2009
    nice! are you concerned at all about the pc's heat with it mounted in the cd changer location? perhaps at least drilling some vent holes in the bottom of changer "box" area?
    Variable Bitrate mayhembdm666's Avatar
    Mar 2008
    Adelaide, Australia
    Not to get straight to the point, But how much was the screen? and what resolutions?
    But otherwise, very nice install.. should allow for some interesting things.
    2004 Holden WL Caprice Auto GENIII
    Base System = Raspberry Pi
    Everything else is pending for now as switched from a Mini-ITX setup
    Low Bitrate CherokeeChief's Avatar
    Nov 2004
    Italy
    Nice and clean install!
    It's a Jeep thing...you wouldn't understand !--------------------------------------------
    Aug 2010
    Thanks for the replies folks.
    The PC in the CD changer is actually getting warm, well quite warm after say 1 hr drive home. Yesterday I removed the PC case to test that out but if that fails I shall add a PC fan inside the cd changer unit plastic cover thingy to suck cold air in or push hot air out... not sure yet.
    Aug 2010
    Quote Originally Posted by mayhembdm666 View Post
    Lilliput FA1011-NP/C/T - 10.1" HDMI touch screen monitor @ 205.63 (inc. 17.5% VAT)
    Screen Size (diagonal) 10.1 inch
    Aspect Ratio 16:9
    Resolution 1024600 native, up to 19201080
    Brightness (cd/m) 250
    Contrast Ratio
    500:1
    Viewing Angle (degrees)
    140(horizontal), 110(vertical)
    Pixel Pitch (mm) -
    Refresh Rate (Hz) 60-72
    Response Time (ms) -
    Screen Rotation
    Colour Configuration RGB stripe
    Touch Screen 4-wire, resistive, USB (RS232 version available)
    Video System PAL/NTSC
    LCD Backlight LED
    Video Inputs HDMI, DVI, VGA 15-pin, Composite
    Audio Outputs <1.2W
    Mount Type Desktop stand, VESA 75
    Power Input DC 12V and 240V
    Power Consumption <9W
    Yes plenty of options for the future I hope too
    Sep 2009
    Quote Originally Posted by mp3cherokee View Post
    i was thinking you could cut out large holes in the bottom and in the top lid of the changer box to allow air to flow through naturally. if you have a 1" or larger drill bit, do several holes in a line and then glue in a grill material underneath the lid to give it a nice finished look. then if that still didn't cool it enough, you could always add a couple small fans... just some ideas.
    Aug 2010
    Quote Originally Posted by theksmith View Post
    I think I will do the 1inch holes underneath to start with but as I have cut the dashboard I may as well cut the cd lid thingy
  1. install HELP, POST one beep, no monitor?
    By SkyLLZ in forum General Hardware Discussion
    Last Post: 05-22-2009, 12:00 PM
  2. Carpc or Carputer Complete Guide
    By smhussain in forum Newbie
    Last Post: 04-21-2009, 05:58 AM
  3. Bugbyte's 2001 New Beetle -Mac Mini Install
    By Bugbyte in forum Worklogs
    Last Post: 05-15-2008, 04:31 PM
  4. 1993Opel Vectra carpc install
    By [mp3]neo in forum Worklogs
    Last Post: 11-12-2005, 08:22 AM
  5. FS: Complete CarPC with Lilliput Monitor
    By Krystos in forum Classified Archive
    Last Post: 12-23-2003, 03:43 PM
