Results 1 to 10 of 14
Thread: Face lifting my most loved baby - new legs & the perfect 8" double-din install
    Aug 2010
    Its been just over a year since I bought my 2. Though the car has very few miles on it and has been garaged all its life, my problem of being an idiotic perfectionist drove me to tune & replace parts most of this year.
    The beginning of last month, I was left with two primary upgrades to accomplish - New Legs & a New Din & with both fitted, its a joy to post this thread -
    Need to start by thanking my friend Vaibhav & both of us dearly THANK this forum for all the information it houses, I wonder where we'd go looking for answers had it not been for this place.
    (I'm a sucker for stock when it comes to the car's engine & body therefore care was taken to ensure no cutting & pasting around the original dimensions of the interior.)
    The Baby (1990 Toyota MR2 JDM - Turbo)
    The Goods
    Carputer-
    IBM Thinkpad R52
    IBM Replicator II (Cable management is great)
    8" Lilliput 869 (From mp3 store)
    GPS receiver (From mp3 store)
    Space Navigator SE
    Rubber Keypad (forgot brand)
    Belkin 7 port usb dock (output 5v 3.8amps, powered by adaptor - 220v in, 5v/3.8amps out)
    Belkin AC-DC converter 12v input, Max 200w output (currently happy to power screen, laptop & Belkin USB dock)
    Laptop power on incorporated to dash with laptop mounted permanently under seat with replicator.
    Secondary acc switch incorporated
    Wheels -
    Lenso 16" NX
    Tyres -
    Front - Yokohama S Drive 205/50
    Rear - Yokoham Decibel 225/50
    I've yet to take worthy pics of these, will post soon.
    The Ugly
    The End
    Learning -
    - There are potent 220 volts running in your car with a DC-AC converter set up & if you're not conscious of it, those volts can bite you in the donkey.
    - A 7" double din for the MR2 double din slot is a waste of active area with 8" screens around. I was shipping across the globe, therefore accurate measurements were critical
    (Stripping the frame & setting the screen behind the dash cavity - and the first view of the front was blissful.) Can't say for other cars.
    - No matter what quality, AC converters if starved of power will surely blow fuses & short circuit in their core.
    - Give the GPS receiver some time to figure its whereabouts post first install
    - It pays to run a secondary ACC switch... will suit your moods, every day's not the same
    - The space navigator can be a pain to start control with but given some time & calibration, it can prove a wonder.
    - The rca output cable from cpu to system's aux in... ground it on the stereo/ head unit side & it'll take care of most of the noise interference. Don't f with it unless your power is off/ volume is nil.
    I'll get home & take some shots of the control buttons to power Thinkpad & ACC secondary + pics of new wheels.
    Thanks for reading & thanks once again for all the resident knowledge & resources here. Pls let me know what you think
    (Sorry for the crap pics)
    Jan 2005
    Richmond, VA
    nice install, i've been looking for a mr2 for a while. How many miles you got on it? your mr2 is in great condition.
    Aug 2010
    Thanks Kasemodz, its inside 40k & compression tests show stock values.
    If you're looking for a good MR2 buy & need the exact forums, mr2.com & mr2oc.com if you've not visited already. Owners have some very clean 2s & there's a good car up for sale every now & then. As we speak, there are a few. I'm registered on both these forums as TrakTurtle & would be glad to help in any way.
    Glad you liked the install
    Newbie kensbey's Avatar
    Jul 2008
    brisbane australia
    WOW! great job, looks great.
    is that keyboard removable? do you find it uncomfortable to twist and type? ever hit it with your arm by accident?
    do you get any noise using the inverter? i used to get shocking noise through my stereo when using one.
    _-_-_-_-_-_-_-_-_
    Holden FTW!
    Carpc Mk 1
    Carpc Mk 2 (in Progress)
    Aug 2010
    Thanks Kensbey, its a rubber pad... just roll it & dump it in your car console when not in use. The photo you saw is just one place it can be used in... it works perfectly on the lap, dash...anywhere.
    I grounded the aux in input cables on the Pioneer Head unit side & that took care of any noise. Whatever was left was eliminated with more ground across various points in the circuit.
    Aug 2010
    Wheel pic
    Aug 2010
    Front, side & rear
    Sep 2010
    looks good! did that 8" lcd fit perfectly in the double din with out cutting a bigger hole?
    Aug 2010
    It was a simple - remove lcd frame & place lcd in din slot operation mate... not even a file used to accomodate screen
    Sep 2010
    wow exactly 4x7 viewable area? nice im going to pick 1 up, thanks a lot!
  1. Double din case with swivel face
    By jetkit in forum Fabrication
    Last Post: 06-06-2008, 11:44 PM
  2. Question on double din
    By jdiazj1 in forum Newbie
    Last Post: 02-08-2006, 03:54 PM
  3. What screen will fit in a double din?
    By vdubpsu in forum Newbie
    Last Post: 06-07-2005, 03:46 PM
  4. Can 7" touchscreen fit in double DIN opening?
    By RDaneel in forum LCD/Display
    Last Post: 02-26-2004, 01:53 PM
  5. Replies: 6
    Last Post: 10-21-2003, 03:33 AM
