Ok now on to the PC. This was a complex endeavor and involved quite a bit of research before deciding on a system. I needed something compact but also needed/wanted a TosLink optical out to go to the Zapco DAII DAC. The first PC I ordered met these requirements but the case it came it just wouldn’t fit where I needed. So I have a buddy build a fiberglass case that fit into the cubby hole in the back and installed a metal plate to act as a shelf for mounting. I took all the components out of the case and installed into this box.
http://img.photobucket.com/albums/v1...C/P7094598.jpg
http://img.photobucket.com/albums/v1...C/P7094599.jpg
http://img.photobucket.com/albums/v1...C/PA184816.jpg
http://img.photobucket.com/albums/v1...C/PA184817.jpg
http://img.photobucket.com/albums/v1...C/PA184819.jpg
Seemed like this would be a great idea…and it would have been. However, something with the motherboard on this PC just did not like the power supply or the environment or something because it kept having power on and power off issues. Just would not boot right in the car with the Opus power supply but would boot just fine with a regular ATX desktop supply. After screwing with this for a week, I finally canned it and decided to use it in another project. I bought a new PC…this time in a case that would actually fit in the cubby hole in the back. I mounted the power supply inside the case so the unit was a nice contained unit. This did the trick and is the PC in the car today. I added a second hard drive to hold all the music, videos and pictures. The primary HD is for the OS and software.
http://img.photobucket.com/albums/v1...C/PC184915.jpg
http://img.photobucket.com/albums/v1...C/PC184918.jpg
http://img.photobucket.com/albums/v1...C/PC224926.jpg
http://img.photobucket.com/albums/v1...C/PC224928.jpg
http://img.photobucket.com/albums/v1...C/PC224931.jpg
I back up this PC using Windows Home Server and the connector software and that keeps a nice backup to restore in the event of a catastrophic failure. I’ve had to use that a couple of times and damn glad I had it as it made life quite nice for me.
Jay
